Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th July 2012, 03:45 PM   #11
Do they specifically state mu metal? If so I am very suprised.
Old 29th July 2012, 04:51 PM   #12
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
From most of the RG integrated models to the $20k monaural power amps.
http://www.symphonic-line.de/0501_sy...rstaerker.html
Skin depth of Mu metal at 50-60Hz makes foil useless, thickest i have is 0.1mm
A can in Mu metal with 0.5-1.0mm wall thickness for a 300VA size does ~$150, cheaper options.
Not so much,.......if it says "ZM" in the corner.
Old 29th July 2012, 05:58 PM   #13
That's very interesting, $150 is quite reasonable. I couldn't find a list of sizes on his website. Is this something you contact him directly for?
The aluminium is 5mm, I have Ultraperm 80 sheets of Mumetal. I'll put them on anyway as it's a nicer finish than the alu alone.
I also notice the on the photo you posted the only openings are at the base (regarding ventilation).
Making CT transformers from two transformers infernal Parts 1 14th July 2011 08:42 AM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 11:38 AM
Transformers...which ones? Doovieman Chip Amps 5 3rd August 2004 07:07 PM
Would these transformers be of any use to me? :D SkinnyBoy Solid State 14 9th June 2003 11:35 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
