Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th July 2012, 06:06 AM   #1
Default Remote control switch for power amplifier
I am building a 3 channel power amp using the T4 from hifimediy and a 800WRE SMPS. I would like to add a remote control on/off function to the amp and I found this:
Remote Control Switch & Receiver AC/DC 240VAC10A200M2CH | eBay
If I put this between the SMPS switch output and the power switch would it work?
Old 28th July 2012, 06:53 AM   #2
sofaspud's Avatar
If you use the RC, do you still need the power switch?
Would you rather switch the SMPS input instead of the SMPS output?
You could probably employ all (RC and manual) using something like a diode-OR function at the switch.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 28th July 2012, 07:28 AM   #3
The Connexelectronic SMPS800RE has an onboard IEC connector for mains input and a separate output for the switch. I could just use the RC and not a separate switch. The manual for the SMPS800RE refers to: '10A 250V AC rated switch must be used in order to connect or disconnect the mains voltage'.
I assume that I could use the 12V AUX output from the SMPS to power the RC switch and receiver board?
Old 3rd October 2012, 01:44 AM   #4
I having some problems getting the SMPS800RE to switch on using the remote control switch. The picture below shows my setup, with the only difference I have now, is that an additional N and L wire goes to the 800RE power switch. I can power on the remote switch and it works, but the 800RE doesn't power up.
I would really appreciate any help with the wiring. I couldn't find any information on the power switch polarity on the 800RE... does this matter?
Capacitor Across Power Switch to Control Switch On Noise? DreadPirate Analog Line Level 20 21st April 2013 02:58 PM
how to remote control a rotary switch based attenuator Giordano Parts 40 29th October 2008 08:01 PM
Remote power switch Dan2 Power Supplies 10 11th February 2008 12:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
