convert +12 to +/-12 - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd August 2012, 09:16 PM   #21
theAnonymous1's Avatar
Hmmm.... maybe an interference issue then. Might have to experiment with input/output filters. Maybe a RC and ferrite on the input and CLC on the output. At the very least try some low impedence caps on the outputs.
Old 4th August 2012, 04:42 PM   #22
So I hooked up a new one the way I think it should be hooked up just to make sure I wasn't missing something else. Well when I conected teh battery power to the system the dc to dc converter went up in smoke.
Back to the drawing board :-(
Also when I connect power from the battery there is a pretty big spark.
If I was to put some filters on the input of the dc to dc converter what would I use?
I think I am going to order a different version and manufacture. I have already toasted two of these at $29 each LOL
Mike
Old 4th August 2012, 09:35 PM   #23
sofaspud's Avatar
A diagram of your set up would be most helpful. Seems to me there's a fault or mismatch somewhere.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 4th August 2012, 11:04 PM   #24
The only thing that would really cause that was if the polarity was reversed on the converter input.
Old 6th August 2012, 06:25 PM   #25
Here is a diagram of my system. Not the most sophisticated drawing but you get the idea :-)
Old 7th August 2012, 12:23 AM   #26
sofaspud's Avatar
That looks right to me.
I seriously doubt this is a question of improved filtering from a battery supply. IMHO you need to remove all the extraneous connections and get the proper 48V and 12V DC supplies to the amp board. Then add connections one by one until everything is together.
At idle there should only be about a 1 watt draw from the converter. To me the problem suggests something with the connections or something on the amp board.
Old 7th August 2012, 01:11 AM   #27
I thought the same thing and just hooked up the amp to power and it fried the dc to dc. Maybe I got some bad converters or maybe when I am soldering the connections I am getting it too hot.
I ordered a different kind of converter so we will see.
MP
Old 10th August 2012, 07:59 PM   #28
OK I think I may have figured out a problem.
The DC to DC says -Vin and +Vin. does that mean it is looking for a -48v and not just a ground or common?
My 48v power source is a Battery, I dont think the ground is a -48v but I could be wrong.
IcePower says the -48v input is common ground on the amp board. So basically it is connecting the - on the input and the common on the output of the DC to DC converter together.
Could this be my problem? and if so what do I do?
Mike
Old 10th August 2012, 08:30 PM   #29
6L6 is offline 6L6  United States
6L6's Avatar
Have you connected just the battery to the inputs of the murata converter and measured the output voltage?
If so, did the voltages measure correctly (I.E., +12 from hot to ground, -12 from neg to ground and +24 across neg to hot?)
Or are you trying to do everything all at once?
Old 10th August 2012, 10:02 PM   #30
Yes I did and they measured good.
I just bought another manufacture and hooked it up and it worked. I guess the Murata can not have its input ground and the output common connected which is what the Icepower does on the board.
So I finally figured it out and its perfect!!
Thanks for all the help.
Mike
FAST build with an Alpair 7.3 and a 12" Peavy Pro 12 woofer golgiapparatus Full Range 6 2nd November 2012 12:07 PM
Simulation - Pass MF-12 MOSFET Fully Comp Modification for HK Citation 12 PB2 Pass Labs 0 10th May 2011 03:11 AM
Ultra quiet DC supply +12/-12/+12? phrarod Digital Source 13 10th January 2011 01:33 PM
FS - 12" E-V LT-12 full-rangers dimitri Swap Meet 4 13th May 2009 09:11 PM
WTB ElectroVoice SP-12, 12" FR driver rcavictim Swap Meet 3 8th October 2004 06:33 AM
Copyright 1999-2017 diyAudio
