Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th July 2012, 07:21 AM   #1
bullpeters's Avatar
Location: Right next to beach, a potatoe toss to the whitewater
Default LM1084 5.0 need 6v
any way to trick the Lm1084 5.0 into giving 6v. I believe that the 5.0 version fixed to 5v and i need regulated heaters.A shame to have to buy another adjustable one. Any thoughts?
Old 25th July 2012, 11:17 AM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
From the datasheet, I gather that you just need to insert a suitable resistor in the GND terminal. See p10 of the data sheet: http://www.ti.com/lit/ds/symlink/lm1084.pdf
The typical value should be 200Ω for a 1V increase, but you could make it adjustable for more flexibility
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 25th July 2012, 04:52 PM   #3
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
A couple of diodes in series in the GND terminal works as well (but you may not hit 6.0 spot on then)
/U.
Old 25th July 2012, 07:34 PM   #4
Elvee's Avatar
/U.
It will also confer a ~ -4mV/°C tempco to the output voltage. Might be desirable or not.
Old 26th July 2012, 06:18 AM   #5
RJM1 is offline RJM1  United States
You could use an ADR510 voltage reference from the ground pin of the LM1084 to ground and a 4.7K resistor from the output of the LM1084 to the ground pin of the LM1084 to supply sufficient current for the ADR510.
This way you would not reduce the power supply rejection ratio nearly as much as the previous two examples.
Data sheet.
http://www.analog.com/static/importe...ets/ADR510.pdf
DigiKey.
ADR510ARTZ-REEL7 Analog Devices Inc | ADR510ARTZ-REEL7CT-ND | DigiKey
Old 26th July 2012, 07:27 AM   #6
If you were to use a resistor in series with the ground pin of the Lm1084 the value of the resistor for a typical ground pin current of 55μA would be 18.181K. From the datasheet page 5. The example shown on page 10 was probably copied from the 7805 regulator which has a 5mA ground pin current.
Old 26th July 2012, 08:55 AM   #7
Elvee's Avatar
You confuse the LM1084-adj with the LM1084-5. The latter includes a resistive divider passing 5mA
Old 26th July 2012, 09:05 AM   #8
I guess the adjustment pin current is not the ground pin current. I found another data sheet with different values 7 to 10 mA here. and 3 μA on the adjustment pin.
http://www.htckorea.co.kr/Datasheet/LDO/LM1084-R1.3.pdf
I wonder what the actual current is in the LM1084 as I don't see it on the datasheet?
Old 26th July 2012, 09:18 AM   #9
Elvee's Avatar
Since it is a 3-pin device and it has to comply with Kirchhoff's law, Iadj necessarily equals Ignd.
Iadj applies to the adjustable version and Ignd to the fixed ones, but it is purely a terminology issue.
Anyway, an adjustable resistor of 220 ohm in the ground terminal will cover all the range of possible currents for the fixed type, and will not appreciably degrade any of the characteristics
Q about connecting transformer 6v-0-6v Hubba Power Supplies 5 10th November 2010 09:12 AM
problem with LM1084-circuit in 41hz.com amp6-kit yumiyoshi Power Supplies 2 11th February 2010 02:18 PM
6V Vibrator Refurbish? 65blkbkgt Car Audio 3 6th February 2009 03:19 AM
6v 5AR4? pftrvlr Tubes / Valves 7 9th February 2008 01:32 AM
how do you convert 9V to 3.6V Gizmotech Parts 6 27th March 2005 05:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
