Wanted - Schematic diagrams for Artesyn ( Sun V880 Server ) Power Supplies.
Old 27th July 2012, 11:43 PM   #11
kimbal is offline kimbal  Australia
kimbal's Avatar
Just to give you guys and idea of the complexity of this project - it's nothing like what has been previously mentioned.
The daughter "control" board I spoke of has 28 surface mount IC chips ( an an uncountable number of micro chip parts as well ) within a double sided PCB that I guess is about 6 x 4inches in size - that you can only read information with a magnifier. The tracks that wire them are hair thin, maybe thinner in places.
Additional to that, there is a 48 pin 90 degree header connector joining the daughter and mother PCB's together ( yes the bastard is soldered on ) and the tracks again are hair thin.
Even with my wizz-bang new Xytronics DIA-60 De-soldering Iron ( which went out cheap at "Tricky Dicky" - Dick Smith - a few years ago ) and a new tip, I'm having great trouble just de-soldering the header connector joining the 2 boards because of the through hole plating.
Adding further insult to injury - all the the parts on the daughter PCB are surface mount - which I hate - as I can't see the bloody things without glasses and a magnifier. On the other PCbs you have about 15 large heatsinks scattered about with chip components buried underneath - meaning the heatsinks have the be removed to see the PCB wiring below. ( maybe I've lost the plot on all this and need to get a life !)
The main connector that connects the enclosed power supply module into the server has a small 24 gold pin secondary connector ( using all 24 pins of course ) back into the main server wiring. Having information on this wiring hookup will at least get the bugger to activate on the bench - before any mods can be done.
So the task of just getting the supply fired up on the bench is a challenge in itself.
The up side to all this is - the Manager of one of the US Companies I emailed, has gotten back to say "I need the service documentation" ( dah !!!) which he is looking into chasing for me ( but don't hold your breath waiting for it ! ).
If I can procure this it "might" ( I say "might" - because I'm still not confident its a plug and play setup. ) save, me a lot of grief.
I'm quite concerned de-soldering the PCB's will stuff them once and for all, because linking broken tracks is not realistic in this sort of manufacturing technology.
Anyone got any better Ideas !
( Maybe at the end of the day - I'll just go and buy a big power supply and be done with the hassle ! )
kimbalsummers@hotmail.com
Old 30th January 2013, 10:40 AM   #12
CrezZ is offline CrezZ
Connector Pinouts - Sun Fire X4600 and Sun Fire X4600 M2 Servers Service Manual
this is pinout for power supply SUN, but newer model then v880. But pin A1 is PS_ON - I think that is it.
Old 8th October 2013, 07:25 PM   #13
chadez is offline chadez
I just did some reverse engineering on this psu. I took the control pins out of the box using a ribbon cable and measured the voltage levels when the psu was connected to the computer as well as unconnected. Results can be seen here: https://docs.google.com/spreadsheet/...UE&output=html
There were two pins that got my attention, #3 and #16 as they seem to get grounded when the power supply is running. So I shorted these pins to the ground, powered the device and voilą!, it came up, steady as hell
It is very well designed and built psu and it can give lots of power to any of its rails, requiring no load to others.. well, at least to my favorite one, 48V rail. I took 260W out of it (I didn't dear to feed more in my 20W resistor) with no problems.
Oh, yes, the ground I believe can be found from pin #15 and the pins closest to the control connector in ports A1 and B1.
I believe this was my first post on this forum! I hope people find this information useful
Wanted - Schematic diagrams for Artesyn ( Sun V880 Server ) Power Supplies.Hide this!Advertise here!
Shanling scd-t200c circuit diagrams wanted MadMutt Digital Source 16 11th December 2015 08:12 PM
Free Tube Amplifier Schematic Diagrams gozilla Tubes / Valves 5 1st August 2010 08:15 PM
DNM Power Amp Circuit Diagrams Wanted mozfet Solid State 3 29th August 2009 10:10 PM
Onkyo TX-8511 Schematic Diagrams space2000 Solid State 1 27th March 2008 11:04 AM
Schematic Diagrams for Free dmfraser Digital Source 0 30th January 2004 11:44 PM
