Quick question on grounding procedure - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd July 2012, 05:27 PM   #1
ZLyzen is offline ZLyzen  United States
Default Quick question on grounding procedure
hello,
I have be reading topics on grounding all morning, and to no surprise to some others who have gone there looking for advice, not much has cleared up.
Here is my setup, and what I plan to do. Can someone tell me if there is a red flag anywhere?
I'm building an powered speaker setup, 2.1 style.
I will have a sub with all the "guts" and 2 small bookshelf speakers will plug into this like an amp.
The sub will have 3 circuit boards in it, all mounted (isolated of course) onto a metal back panel of the sub, much like a plate amp, and there is a 120VA transformer.
There will be a psu circuit board, pretty standard 4 4700uF caps, with some other small ones, and a 317 337 arrangement to power the op amps.
There will also be a preamp circuit board, the potentiometers will be mounted on the back panel, and they are the pcb pin style, so no wires there.
Any finally there will be a power amp board, a bridged lm4780 for the sub, and a lm4766 for the satellites.
This was going to be my grounding technique.
Center of primary connected to chasis (obviously)
there are 2 secondary windings, so these will be combined in series on the psu board, the output of this board will go to: the power amp, and the psu's ground will also go to the chasis.
Finally the ground for all the inputs will be on the preamp board, and this will connect to the chasis where the psu board is connected.
Anyone see any glaring problems with this technique?
Thank you to anyone who takes their time to work through this
-Zack
Old 23rd July 2012, 05:59 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Your scheme sounds good. Sometimes, I found good (when there isn't DC returning by ground, like the split power supplies), to separate input ground and power ground by a little resistor like 10-100R and without a bypass. So it breaks ground loops, and in case of wrong connections, the R blows.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 28th July 2012, 10:36 AM   #3
jitter is offline jitter  Netherlands
jitter's Avatar
Did you read this excellent article?
Quick guide on Grounding OnAudio Solid State 46 12th December 2012 06:43 PM
Scott 233 Bias procedure question Wharf_Creek Tubes / Valves 2 30th November 2010 04:48 AM
quick grounding question gain Power Supplies 7 22nd October 2008 04:19 PM
Quick question about star grounding jn2630 Tubes / Valves 8 21st January 2008 02:31 AM
A quick (haha, no really) grounding question geaugafletcher Chip Amps 2 22nd December 2006 03:53 PM
Copyright 1999-2017 diyAudio
