Gentlemen,
For my Project I Need a 80v regulated Supply. I have a double rail +80V/0V PSU. I'm only a mechanical engineer and Need a prinicipal Sketch how it Looks like ... See also here: DIY Project - Nytech CPA602 today ... Thanks for your help ... |
#2 |
Looking at your other thread I'm assuming the 80 volts regulated is at very low current ?
If so a simple zener regulator is ideal (3 series connected 27 volts zeners) fed via a resistor. A small cap is placed across the three zeners to maintain a low impedance clean supply. The resistor value is calculated by knowing the voltage feeding the chain (which has to be higher than 80 volts) and the max current the regulator has to supply.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 | |
Or does it makes sense to use a regulater like the LM317 ...? |
#4 |
I'll draw it... give me a few minutes.
#5 | |
The zener chain as suggested above will do the job in this case. |
#6 |
Like this. Resistor is calculated with ohms law to allow a few millamps to flow in the zeners.
eg, 100 volt unregulated. R=V/I so R=(100-81)/0.01 which is 1900 ohms. Use 1800 ohms as preferred value. So that allows 10ma to flow in the zeners. The load (the amp) draws from that 10ma. If the load were 5ma then the zener current would reduce to 5ma with the above values. Always allow at least around 5 ma to flow in the zeners at all times.
#7 |
Wonderful :-) I'll setup a schematic for the modified PSU today evening and will post the schematics.
There are also regulators available with higher voltage .... e.g. TL783 from Texas Instruments .... |
#8 |
The zener type shunt regulator takes some beating with its low output impedance. I think they will give the cleanest possible supply.
The TL783 is an interesting choice but not without precautions. This type of regulator needs a minimum load applied at all times in the region of 15 ma (absolute minimum) so that could make it more inefficient than the zeners.
#9 |
I'll do it with the zener shunt regulator .... And again I learned something :-)
#10 |
I was just looking at the circuit for the Nytech.
There's nothing to stop you using a "double" zener regulator. Use an 80 volt one as mentioned and add a 50 volt one for the bias network fed from the 80 volt one.
| 3 Pin regulated supply VS zener based supply | KevinLee | Solid State | 3 | 15th September 2008 02:40 PM |
| Best regulated power supply. | JC951t | Digital Source | 20 | 14th November 2007 09:04 PM |
| Nakamichi PA-7E/ 80V DC Voltage of main Supply | deq2496 | Solid State | 9 | 12th January 2007 02:50 PM |
| Regulated power supply | akunec | Chip Amps | 3 | 5th November 2006 10:27 AM |
| Class D Amplifier Power Supply Design -> 12,5 A @ +/-80V = 1000W | selfservice | Class D | 22 | 1st September 2006 01:20 PM |
