Hallo! I am a new diyer. Trying to build PSU for my preamp tube. It requires 3 secondaries output. So far, I need to combine 2 transformers (based on edcor, hammond and antek design) . I'm wondering if anyone know where to buy 1 transformer in USA that can supply all 3 secondaries output.
Also, is there any company offering transformer kit? I am willing to learn. I am attaching the scematic. All is the same but the primary (input) should be 115V (US). Thanks! |
#2 | |
#3 |
If you're not drawing a lot of current for the regulated supplies, you can wind the secondaries on the existing torroid without a lot of difficulty -- by taking one of the 6.3V windings and adding to it.
I've used transformers from discarded Eico, Heath and Knight test equipment bought at hamfests an online. A lot of these devices used 6X4 rectifiers, etc., etc. |
#4 | |
Can you give me link to some literature to do that. |
#5 |
Did you check Antek AS-1T250? This have 3 winding 250 volts and 2 winding 6.3 volts. At least you have 2 in one. Also did you talk to them they may make one custom made for you. |
#6 |
Edcor will build to order exactly what you need for a very nominal fee, although there is a $40 set up charge to make it. They may also have something close in their catalog already.
You could use this one with an additional transformer for the 15V supply.. http://www.edcorusa.com/p/588/xpwr001_120
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#7 | |
Measure the voltage coming off the 10 turns, measure the voltage the voltage of the 6.3VAC winding. I'll let you do the maths -- the ratios will tell you how many turns of #18 wire you'll need to bring the 6.3V winding to 15VAC. When incorporating the additional turns you need to keep going in the same direction as the 6.3VAC |
#8 | |
Do I need to discard the 6.3v winding and restart from the beginning or just add (solder and isolating the existing 6.3v winding with new wire) until come up with 15V? Other topic: what do you use to make it magnetic shield? |
#9 | |
"If I want to modify 6.3V to 15V, I need to add winding. Instead: can I take one of existing 250V, reduce the winding and make it to 15V?" |
#10 | |
All the trouble I've ever been in started out as fun......
| Greetings from Minnesota, USA | jordheis | Introductions | 3 | 9th January 2011 11:04 PM |
| Micronta bench power supply & 110V-220V converter transformer USA | boywonder | Swap Meet | 0 | 3rd October 2010 09:57 PM |
| Hi from the midwest USA | twilightsentry | Introductions | 3 | 16th September 2008 03:01 PM |
| Chaning transformer wiring from USA to UK mains | A Sanchez | Power Supplies | 4 | 3rd June 2008 10:37 PM |
| Hello from the Carolinas USA | sweet | Introductions | 8 | 30th December 2004 08:16 PM |
