#761 |
Ap2,
I don't think that if we had loudspeakers that actually produced usable output to even 20hz flat with the power output of the rest of the bandwidth of our speakers we would have any happy neighbors. I know that even at higher frequencies it is hard for our homes to contain those low frequencies. I am not talking about using sub-woofers, those are typically such narrow band devices that I don't consider that a normal part of a regular loudspeaker. |
#762 | |
So at least for the amplifiers PSU I wouldnt expect one to have to size ripple at this lower 2-4Hz. Thanks -Antonio |
#763 | |
#764 | |
I was able to find the minimum capacitance for those cases, too, within 1000 uF I think. I am at work and the numbers are at home but I believe that they were 10000uF, 11000uF, and 6000uF. I would need to verify those, if anyone wanted to rely on them. And I think I did those with a positive-only square wave, for some reason, and then started messing with the .meas commands and never got back to continue with the square waves. But whatever the minimum C numbers are for squarewaves at the same peak amplitude as the sines, using those values (or more) for reservoir capacitance should give very high confidence that the C value is at least not too low for the power supply to handle the peak output signal, regardless of waveform type. Regards, Tom Last edited by gootee; 22nd August 2012 at 05:40 PM. |
#765 |
The signal itself would/shouldn't have to go as low as 4Hz. That marker is just to reduce phase shift of the roll-on filter at the "usable" start of the audio band, around 15Hz and up signal wise. I have the roll-on filter on MF-80 set at 1.5Hz. Try it, it will be a whole new bass experience when you're 'used' to higher frequency roll-on filters.
Negative Feedback: The Need for Speed |
#766 |
MagicBox,
I think that we are all in agreement that a wide bandwidth in the amplifier is important and that we don't want the band pass filters to get into the audio range. How much difference there is between 1.5 hz and 4 hz I don't know without doing the math and seeing how far that shifts the high pass frequency where it is still flat in the pass band. I don't think that anyone is going to argue this point, at least I hope not. |
#767 |
LF rolloff is not really relevant to this thread, but there may be good reasons to limit the bandwidth. There is little point in forcing a transducer to attempt to reproduce a frequency which it cannot handle. There will already be significant LF phase shift from the loudspeaker, and this would be a second or third-order rolloff. A first-order rolloff from the amplifier could be harmless in comparison.
#768 |
DF96,
Isn't that what MagicBox is referring to in his statement about the roll-on frequency he is setting at 1.5hz? Perhaps I am missing something here. |
#769 |
A roll-off of 15Hz might be more sensible than 1.5Hz, unless you have a very big room, very big speakers and definitely never use a turntable. I was disagreeing with your suggestion that we all agree about wide bandwidth. I prefer appropriate bandwidth.
#770 |
DF96,
I agree and often wonder about some who insist on needing a system that actually produces bass down to 20hz and over 25khz. I have good hearing and I know that 25Khz is out of my range, though I still get up to about 20khz. And what besides a pipe organ or a steam train or synthesizer has anything musical at 20hz? Not a stand up bass or anything like a normal drum head or any orchestral instrument that I can think of. And yes I do still have a turntable and albums in my collection. Nothing like the rumble of a low note getting into feedback with the turntable and arm. I have been to many a live show behind the mixing console and I always see the low frequency cut set higher than 20hz. Bass feedback through the mics can be worse than a high frequency feedback if it just barely is perceptable. I can't even stand the sun roof open in some cars, the low frequency rumble will drive me nuts. |
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
