#721 |
Not so sure Big VA is always so desirable...charging will be short and steep...I have a feeling the over voltage will be better. Like running the amp at 60 V and only allowing 50V swing. (or what ever the numbers might be) then it would be possible to have some voltage over the signal level at all time regardless of the current output, like an effective way of separating the voltage from the current.
#722 |
I agree that the bridged LM4702 type output stage is amusing, for that much cash.
(likely that stuff wouldn't sell as well at half the price)
Not so much,.......if it says "ZM" in the corner. |
#723 | |
I think this is an useful thread (apart from the 'noises off'), but your searches via simulation may need to be better informed by 'ideal model' algebra as that will guide you to the tradeoffs which a simulation can sometimes obscure. Of course, having found constraints on C you still need to take account of other issues such transformer heating, PSU efficiency, feed inductance etc. as you have said. |
#724 |
DF96,
I would be very happy if we can arrive at some rule of thumb that has at least been tested theoretically and maybe confirmed practically. At the moment most of us are not even guessing close to anything useful. I can almost assure you that you have often also not paid enough attention to your power supply design as it is almost always secondary. Here we talk only amplifier schematics, second and 3rd order harmonic level. Triple EF current mirror.... Never power supply. No disrespect to any of our members starting a thread believing that they are offering the best sounding amplifier ever. Just look at the SIMS slew rates of several thousand volts per uS, a bandwidth ranging from DC to Daylight and very low H2 with H3...... Totally forgetting to discuss the accompanying power supply with equal enthusiasm. But power supplies are boring, it is a transformer normally salvage from some other equipment and capacitors, enough to arc-weld with, bypassed by some little cap for HF luck plus a resistor that will discharge it over a fortnight. Unless everything is equal no-one that builds this amp could for the love of god have the same results even if they all agree that it simulates perfectly.
Kindest regards Nico Last edited by Nico Ras; 19th August 2012 at 08:38 PM. |
#725 | |
DF96 Thats a pretty interesting take, I've never seen this issue presented this way. Thanks for taking the time. "So yes the early effect may or may not be significant (equivalent to some -60db) but it sure is helpful to review the impact." I roughly calculate -70db but rounded down. Hope this helps -Antonio |
#726 |
many ways to skin a cat...
#727 | |
Frank |
#728 |
Steven @ #713:
EE- & EI-core have small air gaps - the laminations dont quite meet up, and are insulated. Even a very small air gap (10's of um) has a significant (beneficial) effect on the saturation performance - it "tilts" the BH curve, reducing B (lfux density) for a given H (MMF). Toroidal (tape-wound) cores do not have an air gap, they are wound from a single strip (unless they are "cut-cores", which have been sliced in half, etched & lapped & glued back together - specifically to create a small air gap).This means that the toroidal cores saturate sooner, and more abruptly, than EE/EI cores. A secondary (har har) effect is the coupling. line-frequency EE/EI cores are usually wound with a split bobbin - primary on one half, secondary on the other with a big divider in between. This is great for electrical safety (isolation/hipot/safety regs) but absolutely terrible for magnetic coupling - the windings dont occupy the same volume. This results in high leakage inductance (which turns into poor regulation). Toroids inherently have better coupling as one winding encloses the other. You could wind a toroid so this doesnt happen, eg primary on one half of the toroid, secondary on the other - but your xfmr manufacturer will probably stab you with a pencil if you suggest it (I've seen it done at HF in SMPS & RF gear, to minimise capacitive coupling). This means the toroidal transformer has lower leakage inductance than EE/EI transformers. And the leakage inductance (plus the resistance, but leakage usually dominates) is all that limits the short-circuit = inrush current. So toroids saturate harder and faster than EE/EI cores, and suck more current when they do. So what, you might ask? I suspect this means the toroid will be designed with a peak flux density that is somewhat lower than the saturation flux density Bsat, to prevent saturation at peak line voltage cos its so nasty. It'll still saturate at turn-on, hence soft-starting (and even if it didnt, the DC bus caps need soft-charging). Whereas EE/EI transformer designers exploit the small air gap, and push the peak flux density very close to saturation. this allows them to reduce core material and/or turns, saving money and weight. The resulting saturation is what creates the nasty peaks in the no-load current waveform. My guess is that manufacturers of decent audio mains transformers DONT do this, but I might be wrong. If we use a "T" model with primary and secondary resistances & leakage inductances (Rp, Rs, LLp, LLs) along with the primary magnetising inductance Lm, we see that the magnetising current flows through the Rp & LLp, then down thru Lm - it does not flow through the secondary. The secondary current flows thru Rs & LLs, then is reflected to the primary and flows thru Rp & LLp (but not thru Lm). So when the transformer saturates, Lm drops rapidly, so the magnetising current rises rapidly, Im => Im_sat. This extra mag current drops even more volts across Rp & LLp, which reduces the voltage across Lm. And that voltage is what the transformer reflects to the secondary: Vsec = [Vin - (Imag + Isec*Ns/Np)*(Rp + jwLLp) ]*Ns/Np [Microwave Oven Transformers actually exploit this - under no-load (Isec=0) the core fully saturates each half-cycle. But under load the Isec*(Ns/Np)*(Rp + jwLLp) volt drop reduces Vmag enough to prevent saturation. Its a sneaky trick, and means if you test an MOT with no load it will look like its faulty - I measured a 230V MOT drawing 6Arms no-load!] Conclusions: If your power transformer does not saturate (no-load current looks pretty sinusoidal) and the magnetising current is small (say < 10% of rated current) then you can ignore the Imag*(Rp + jwLLp) voltage drop. This means you can reflect Rp and LLp to the secondary and lump them in with Rs & LLs. This is a very simple model, comprising Ns/Np, Rs' and LLs' (which include the reflected Rp & LLp) Conversely if your power transformer does saturate, and/or the magnetising current is large, the Imag volt-drop term is important, and you need to use the full "T" model. Anyone got a bunch of different power transformers for audio amps lying around and can test this? all you need to do is look at Ip with no load...... |
#729 |
Some links to papers with equations for linear power supply circuits:
http://www.google.com/url?sa=t&rct=j...W1jkDQb5cKrqDw http://techpreservation.dyndns.org/b...20Part%201.pdf http://cbasso.pagesperso-orange.fr/D...lculations.pdf Last edited by gootee; 20th August 2012 at 05:41 AM. |
#730 |
Frank/Tom, thanks for the links it should be good for refreshing the memory and rid some of the cob-webs. However, I think that your simulations has been far more revealing in what effect it has on what we hear than purely the equations available.
I remain thankful for what you guys have done thus far it has been quite an experience to bring the theoretical and practical together in a simulation. Although I do not have an absolute answer yet, I but have a very good foundation and make some practical measurements using a practical amplifier by comparing the input signal to the output signal while changing reservoir capacitor values. This comparison is very simply performed comparing the input- with the NFB signal. My first task is do an exemplary and totally blameless amplifier lay-out and a simple system by which power supply parameters can be adjusted and signals recorded consistently.
Kindest regards Nico Last edited by Nico Ras; 20th August 2012 at 09:18 AM. |
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
