Power Supply Resevoir Size
Old 19th August 2012, 12:43 PM   #671
liching1952 is offline liching1952  Switzerland
Banned
Originally Posted by jacco vermeulen View Post
I have a couple of original late '80s bought Partridge output transformers looking at me, they're saying they'd like a CLC to feed them.
I dun know these transformers. What is CLC? How heavy are they?
Old 19th August 2012, 12:47 PM   #672
R.I.P.
CLC is the circuit that smooths the output of the rectifier.
regards Andrew T.
Old 19th August 2012, 12:49 PM   #673
R.I.P.
Originally Posted by liching1952 View Post
Power= U^2/R or I^2.R so its all the same.
No.
It's not the same, as he stated.
you are looking at resistance as the sole load and ignoring all parasitics.
You are wrong on at least two counts.
The load is not pure resistance.
The supply is riddled with parasitics.
regards Andrew T.
Old 19th August 2012, 12:55 PM   #674
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Originally Posted by AndrewT View Post
No.
Thank you Andrew.
I have a feeling that liching1952 just feels like arguing for the sake of it.
Kindest regards
Nico
Old 19th August 2012, 01:05 PM   #675
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Partridge was a British transformer company.
They weigh a standard bag of potatoes each, go by the name TH4663, afaig there are still a couple of shops that sell them to silly buggers for $1000.
(but if weight is your thing, how about 30lb each Partridge really high current chokes i wrenched out of pro-medical jogg/walking machines ?)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 19th August 2012, 01:09 PM   #676
Banned
No.
Basic physics says, only the resistive part of the load absorbs power, the imaginary part doesnt.
Old 19th August 2012, 01:11 PM   #677
DF96 is offline DF96  England
Originally Posted by gootee
Similarly, for any power amplifier with a linear PSU there is a lowest reservoir capacitance, below which the amplifier will not meet its specifications. How can we calculate the value of that capacitance?
I'm not certain that is true. If you increase the quiescent supply rail voltage enough, it doesn't matter how much it droops (assuming PSRR is not an issue) so you can have a small cap. Your stored energy will increase because of the higher voltage. What you can do is calculate the smallest cap required, given a stated Vdc (exceeding Vpk by whatever margin you deem helpful). You can also calculate the minimum stored energy (see my earlier post) but that merely lets you then choose C (given Vdc) or choose Vdc (given C).
I suspect you are all looking for the gold at the end of the rainbow: there is not an optimum value for C or Vdc, although there may be an optimum combination. Total 'AC in' to 'sound out' efficiency may be a useful parameter, as raising Vdc unnecessarily reduces efficiency.
Old 19th August 2012, 01:15 PM   #678
Banned
Weight more or less gives an indication how they will perform at the lower end. If they are good, so build a good amp with KT100 or so. And what do you mean CLC. AndrewT wrote that it is a circuit smoothing thd power. Does it has anti hum windings for this purpose?
Old 19th August 2012, 01:18 PM   #679
Banned
huh 1000 bugs for 1 transformer. Better buy a good 2nd hand profesional made Beard P100 or Quad for 1500 or so.
Old 19th August 2012, 01:26 PM   #680
Banned
Originally Posted by Nico Ras View Post
I also suppose that you have never heard of power factor correction, specifically to counter this problem.
Yes am MSc but doesnt understand power factor correction so explain.
Power Supply Resevoir SizeHide this!Advertise here!
How do you calculate choke size in a power supply? Burnedfingers Power Supplies 28 19th July 2017 08:03 AM
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
