#651 | |
Banned
If HF is important for good Lf, why does a valve amp sounds better? The transformer hardly goes further then the audio band. |
#652 | |
You are making generalist assumptions. Most valve amps I've heard sound distinctly worse than a good SS amp. But that is my preference/bias. You need to clarify yours.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#653 | |
Banned
The only good sounding SS amps are the Stasis amps by Threshold and Nakamichi. By the way these amps use simple power supplies and may be you can advice them. |
#654 |
Okay, you like all valve amps and only Stasis SS amps. That means we now understand your preconceptions a little better.
#655 |
You heard 'm, folks.
Get yourself a quarter century old, rundown Stasis amp and a set of Sequels, and be done with it. (got to hand it to him, the entertainment value of this troll is top notch)
Not so much,.......if it says "ZM" in the corner. |
#656 | |
just another
liching1952 that last comment is a typical trolling comment. Though I'm sure you already knew that.
#657 | |
Banned
And yes I hear a lot of expensive SS amps, all sounds bad exept the Stasis. Last edited by liching1952; 19th August 2012 at 11:05 AM. |
#658 |
I don't buy amps, expensive or otherwise, I build them.
#659 |
Banned
#660 |
Right, we're getting there. You like most valve amps, a few old SS ones, and assume anyone who builds stuff for themselves hasn't a clue what they're doing.
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
