#511 | |
Banned
Yes its not nice to get critical critism from a low level trilingual new comer isnt it. |
#512 | |
The big point with the cap multi is that you do NOT use a zener and keep the Vds/ce drop as low as possible since the goal is not to build a crude lineair regulator but to increase the virtual capacitance the output devices see.
Negative Feedback: The Need for Speed |
#513 | |
Banned
And, what you all dont see, the thir so called cap multiplr introduce a lot of other effects that lowered the overal performance of the amp thats why I called it nonsence but to be unpolite, its stupid. |
#514 |
To produce audio correctly and unaltered, a good amp has to work at and operate at frequencies up to 10 times the audio band. That's where transient response comes into play, most notable the "T=0" current as I call it. The initial current that needs to be drawn as a result of a change in the system. Propagation delay, parasitic inductance all limit the T=0 current resulting in a voltage sag that otherwise should not sag but deliver the associated, demanded current.
People here are not fighting ripple, PSRR does that like you say. We're past that. We're not analyzing ripple. We're analyzing T=0 current supply any moment the output demands it. And this does not apply to the 'slow' audio signal, but to the HF loop frequency of the circuit. At regulatory frequences, the AC output impedance of a MOSFET / Transistor is rather low; any HF signal on the output transistors 'walks' right through the output device, severely destructing PSRR. Luckily the amp must be stable and as such will not have HF AC regulatory swing (if it does, it can't stable out) for audio signals. But to keep that audio signal in perfect shape, you no longer have to view an amp as an LF amp but as an MF/HF amp operating in the 100KHz - 1MHz area. Edit: Basically the amp has to be fast enough to compensate for its inherent slowdowns in the circuit.
Negative Feedback: The Need for Speed Last edited by MagicBox; 11th August 2012 at 09:05 AM. |
#515 |
Banned
No the amp dun see a bigger cap. There is less ripple but by no mean seeing a large cap. If you use a zener the ripple is zero. Do the amp sees an Infinity cap? Of course not. An infinit cap should supply the amp with current for invinit time which is certainly not the case. What the amps sees is only the small cap at the output. It even doesnt sees the rectifier cap since this blocked by the transistor.
#516 |
Liching1952,
What does a cap multiplier have to do with this discussion anyway? You were the one that brought it up so why don't you answer your own question. Terry, do you say that the mag current from a rule of thumb should be a specific percentage of output current, or better still you have a rule of thumb for number of turns per volt? However number of turns will affect the inductance, so what is the starting point.
Kindest regards Nico |
#517 | |
Banned
And assuming, there are fast transients, what has it to do with a cap multiplier? With a cap multiplier the amp sees only the small output cap, thus less cap then without the circuit. |
#518 | |
#519 | |
In the ideal situation there is no regulatory swing, it'll be Vpp=0. BUT as soon as a delta appears in the system, the regulatory swing will be back to adapt to the change in the system. The quicker and faster it can do that, the better the amp is.
Negative Feedback: The Need for Speed Last edited by MagicBox; 11th August 2012 at 09:32 AM. |
#520 | |
Banned
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
