Power Supply Resevoir Size - Page 50 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th August 2012, 10:15 AM   #491
Banned
Originally Posted by dadod View Post
Actually it is similar to the ripple on the C15(cap connected to the base of the Q30), but at much higher current. You can use small capacitance(470uF in this case) and get it multiplied and thus better filtering with less cost(transistors are cheaper then big elcos). In my amp I use separate C multipliers for input stage and output stage. One very important aspect of this is that all multipliers are very close to the stages, input or output.
dado
I understand how the circuit works. You can even make the ripple zero by putting a zener from base to ground. Driving stages needs ripple free supply but the needed curent is low so a resistor and zener only will fullfil the taske. The output stage doesnt need ripple free supply so why you do this?
Old 10th August 2012, 10:19 AM   #492
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Much different story in the late 1980s, even today, A1244/C3263 are not exactly cheap.
Ever simulated the power supply of a Nak PA-7 ?
(a single 700VA toroidal for 2 channels, 60Vac secondaries, 4 x 33.000uF lytic bank)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 10th August 2012, 10:26 AM   #493
dadod is offline dadod  Croatia
dadod's Avatar
No you don't.
Old 10th August 2012, 10:30 AM   #494
Banned
What has to be simulated? One can also just think. Even when the transistors cost nothink, a cap is better. The circuit you called cap multiplier, is known as old as the valve time but to reduce ripple further a zener is placed from basis to ground. However what is the use for the endstage? Good endstages doesnt need ripple free suply and with that circuit you lost power. Hilaric.
Old 10th August 2012, 10:39 AM   #495
Banned
No you don't.
Look to the conductance matrix of a transistor and find out that the conductance from colector to emiter is practically zero.
Old 10th August 2012, 10:43 AM   #496
Banned
amps need a big cap not to minimize ripple but for another reason. This is neglected and even canceled by the circuit you called C multiplier. In fact its a Cap divider. Huh?
Old 10th August 2012, 10:55 AM   #497
The latest Dartzeel 458 monaurals each have a 2KVA toroidal with a huge oversized core, 4.5 times the nominal power rating.
Mr Hervé Delétraz is from your turf, the things cost 150K a pair, you must find that Hilarious too.
Old 10th August 2012, 11:04 AM   #498
Banned
Does it use a C multiplier? If yes its hilaric, if not, big transformer is may be overkill often done in expensive amps to overwhelm foolisb customers. At least it happens 1 time in the past that a manufacturer put concreet in the amp to make it heavy=good
Old 10th August 2012, 11:08 AM   #499
dadod's Avatar
I am sorry to intrude in this very interesting thread, but I was provoked by this guy telling nonsense about C multiplier .
dado
Old 10th August 2012, 11:09 AM   #500
Banned
and foolish is a customer who buys an amp for 150k
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
How do you calculate choke size in a power supply? Burnedfingers Tubes / Valves 25 5th January 2012 12:23 AM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
Copyright ©1999-2017 diyAudio
