#41 |
The ventilation slots under the capacitors are a nice touch.
Not so much,.......if it says "ZM" in the corner. |
#42 | ||
My own thought on PSU cap sizes is that ripple is a bit of a red herring for the majority of gnf class AB amplifiers since they have very good PSRR. Class A is a different beast and the current draw requirements are so different from Class AB that I don't think one set of 'rules' works for both. I believe that the frequency response of the power supply is more relevant. The output impedance as a function of frequency along with the transient response of the power supply to current demands from the output stage are more likely to affect the overall sound than low level ripple-induced hum. The use of chokes in the power supply can change these things drastically. I've never used a Shunt Regulator, but I suspect they level the playing field by maintaining a low output impedance and good transient response over a wide frequency range. They are power greedy though. And the transient response is not about the caps, it's about the whole shebang, the transformer, rectifiers, caps, wiring and all of the associated parasitics. It seems to me, power supply design can be as complex and as important as the amplifier.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. Last edited by Bigun; 19th July 2012 at 12:07 PM. |
#43 |
#44 | |
But filter caps have another effect other then filtering out ripple, the caps are the power supply for the transistors. Transient response depends on having a low impedance power supply and having a few paralleled cap electro caps bypassed with film caps and proper wring can make for a lower output impedance. It depends on details of how this is done. Those people who hear a difference when they add more capacitance may be hearing he lower output impedance and not the added capacitance. (Remember that ESR adds just like any other paralleled resistance.) Other power supply effects matter too. For example mode switching noise and high order harmonic of that noise need to be "squashed" and some time high ESR caps work for that, Many times a resistor in series with a film cap is used to damp this radio frequency ringing on the supply. Again peole who change out filter caps may be effecting this and hearing more or less RF noise in the supply but thinking they are hearing the effect of more (or less) capacitance. |
#45 | |
Hugh, I respectfully disagree with your discarding the diode front end decoupling merely on grounds of simulation unless the simulations where carried out using a complex stimulus and a power source with finite impedance and you were able to distinguish between signal and signal modulated power rail. The reason I am saying this is because I believe that the width/depth/sound-stage/imaging is a direct result of very low amplitude information contained in the recorder signal. By modulating the power rails due to large currents being drawn by low frequency or other high level signals, masks or smears the low level stuff in such a way that we lose the ambiance (provided of course that it was recorded in the first place). This has nothing to do with the PSSR of the amp, it is not mains or ripple related, but high power signal related, it would not manifest itself in the FFT simply because the power supply rails are "singing in tune with the high intensity stuff" Now I believe that Tom and Andrej (and yourself) may have unknowingly (or knowingly) solved the problem with a distributed power supply. I also believe that your earlier amps may have attracted a good following because they were capable of resolving the "ambiance" as it was recorded. Guy's I am speculating here, but the reasoning seams plausible and I have definitely experienced a chalk and cheese sound difference between the battery and the power supply simply because the battery rails I believe were rock solid and modulation was not present on the small signal power lines. Therefor I would like to state an opinion in that I believe that the power supply has much more effect on the character of the sound than the amp itself.
Kindest regards Nico Last edited by Nico Ras; 19th July 2012 at 03:41 PM. |
#46 |
Quote 'I don't think our ears are that sensitive at 10's of Hz to tiny variances although I've never tried it myself, besides in any normal listening environment the interaction of the speaker with the room boundaries make multiple dB changes to the flatness of the frequency response that are far in excess of any flatness issues from the amplifier (unless damping factor is so low that the speaker-amplifier combo produces it's own bumps in the FR due to impedance changes in the speaker with frequency).'
In an A/B comparison of electronics the low frequency response needs to be flat to not hear any differences between A and B. True it's academic because the differences are less than the Loudspeaker / room interaction. |
#47 |
Andrew posted (about a month ago) that he was taking an extended holiday. Just how extended we don't know but best wishes to him.
regards |
#48 | |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#49 |
Attached is an example of a power supply
![]() The 10NF capacitor ensures that some high frequency noise is cleaned up. The rectifier exibits good high frequency behaviour (it isnt switched by the remaining high frequency noise) because the large 10,000uF shouldnt have low impedance at those frequencies. Thus we have a well behaved supply giving us something close to D.C. Something close to D.C. will not mind interconnecting cables and will safely charge the on board 33uF capacitors. These capacitors are sweet as they respond fast enough in the high frequency region to buffer the interconnecting cables. Thus What the amplifier sees is a stable DC supply. |
#50 |
an audio amplifier is, fundamentally, a voltage controlled current source
of course the power supply is very crucial. i for one am putting 2*15,000 μF on my 2*40 W chipamp yeah the capacitors themselves will cost at least twice as much as the IC
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
