#411 |
Nice. Lets see for the other caps.
#412 | |
#413 | ||
Your opinions may be correct. We can't say, yet. But here in Nico's thread we are trying to actually determine what tends to be better and what does not, and possibly even uncover a "formula" or two for later, so we don't have to do all of this work again every time, or just rely on opinions and hearsay. But suggestions for what to try could be useful. Anyway, it's been a slow process so please be patient. Cheers, Tom Last edited by gootee; 8th August 2012 at 10:20 PM. |
#414 |
If you mean "decoupling capacitance" to mean additional reservoir capacitance placed local to the output transistors, it will help with accuracy of reproduction due to minimizing the effects of reservoir ESR and the inductance of the supply leads. But the rails will still sag, a little slower due to the added capacitance, but to the same level as without for the same output power.
"We monitor many frequencies. We listen always. Came a voice, out of the babel of tongues, speaking to us. It played us a mighty dub… " |
#415 |
I am still not understanding what is happening inside that transformer model.
How can a 25Vac transformer give 73Vdc, inless the regulation is enormous? We know that transformers used for power amplifier PSUs have a regulation between 3% and 10%, that limits the off load voltage. |
#416 | |
![]() Frank |
#417 |
Welcome back, Andrew! We really missed you!
I don't know what makes transformers have regulation. But the model is probably way too simple to account for that. But the way a 25-volt-output transformer gives 71 Volts out is for it to get about 342 Volts p-p as input. It's just a simple matter of turns ratio. Yes, it was not meant for this job. Yes, I used it only because it was convenient and I thought it would be better than an ideal voltage source and an ideal transformer model. Or are you wondering how I am getting 71 Volts when I only put in 321 Volts (instead of 342)? If someone looks at the transformer model schematic (in post 400 of this thread, which is at http://www.diyaudio.com/forums/solid...ml#post3119281 ) and tells me what component values to change to make it more suitable for higher current and voltage than the one the measurements came from, I can change it with just a few mouse and keyboard clicks. Better yet, if anyone has a variac and a suitable transformer to measure, it only takes a few minutes. Cheers, Tom Last edited by gootee; 8th August 2012 at 11:35 PM. |
#418 |
Like this:
AltTrans.gif Trouble is, now have double the resistance in the secondary windings feeding the rectifier, so the sag is even worse at full load, down to around 53V. Which is why you need a transformer with sufficient VA rating, giving better regulation, more cost! Or, use switching mode supplies, etc. Frank Last edited by fas42; 8th August 2012 at 11:48 PM. |
#419 | |
Cheers, Frank |
#420 |
Frank & Tom:
If you remove the entire amplifier & modulated load from the sim, and replace with a resistor, you will see the droop caused by the transformer "regulation" - which will be mostly due to the leakage inductance and the narrow conduction angle. I'd also look carefully at the rectifier model as well - its probably fine, but there are, for example, 10BQ100 spice models with 100R slope resistance (I found them the hard way) |
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
