Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th August 2012, 08:45 AM   #391
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by mightydub View Post
1) rails 20V higher
Transformers must be cheap overthere.
Not so much,.......if it says "ZM" in the corner.
Old 8th August 2012, 09:43 AM   #392
1) rails 20V higher (my rule of thumb, yours may vary) than the maximum output swing so that the rails can sag under load but still be comfortably above the maximum output voltage;
That's just about equivalent to specifying a 180W into 8ohms, (53.7Vpk & +-60Vdc supply rails) amplifier and never using it @ >=100W into 8ohms, (40Vpk).
What a waste of resources and design effort.
Most "Rule of Thumb" guidelines will do far better than applying "-20V" to the supply rails!
If one were working with a 60W amplifier (+-36Vdc supply rails) then the "-20V" rule becomes silly.
Old 8th August 2012, 10:44 AM   #393
fas42 is offline fas42  Australia
But, that 20V does appear at a simple glance to be what's needed. For the sake of consistency, in comparing like with like, I used and adapted Tom's last posted circuit, for the moment "ditched" his fancy capacitor model because there were some spurious glitches appearing in the sim:
The PS rails with no load, the output stage disconnected, sit at 82V. Then, reconnected and idle current flowing, the rails drop to 71V. Finally, add a rather vicious, constant load of summed 20Hz, 635Hz, and 20,000Hz (635 midway point ...) sine waves which peak just below clipping, and see what happens to the rail:
Sags right down to 59V in less than half a second -- that 20V margin doesn't look that bad after all now ...
And what happens to the output with droopy rails? A nice bit of clipping ...
Frank
Old 8th August 2012, 11:00 AM   #394
Fas,
what is the supply rail voltage when the amplifier is delivering full power?
I ask because the 9Volts lost from no load to quiescent load seems enormous, compared to "normal" power amp PSUs. I'd expect to see the supply rails of a 100W into 8r0 amplifier sagging to ~+-45Vdc @ full powwer, from a quiescent of ~+-50Vdc and zero load of +-50.5Vdc. This is 0.5V sag, cf. your 9V sag.
Old 8th August 2012, 11:55 AM   #395
Originally Posted by AndrewT View Post
Fas,
Remember, at the moment, I'm just using Tom's transformer parameters as is, I haven't looked closely at how "reasonable" they are ...
At idle, the output stage dissipates about 13W, 5W in Q3 and Q4, 1.6W in Q1 and Q2. Then, driving with a pure 1kHz tone to just clipping, the voltage sag is stable at 57V. Voltage p-p is just over 100V, and power dissipated in the 4R load is 320W.
Frank
Old 8th August 2012, 12:03 PM   #396
320W into 4r0 is 50.6Vpk (101.2Vpp).
That is a reasonable unclipped maximum from a loaded PSU supplying +-57Vdc, i.e. 6.4Volts of losses through the amplifier. Particularly when the 57Vdc is actually modulated with the PSU ripple (what is the loaded PSU ripple when delivering maximum power?). This leaves the Vsupply minimum ~55V, or really a 4.4Volts loss through the amplifier.
Can you change the transformer data/model to more realistically mimic what a "normal" transformer shows when unloaded/loaded? Maybe Gootee could supply data.
Old 8th August 2012, 12:28 PM   #397
This is where the action is. The transformer, as "supplied", has secondaries looking like this at full power, 320W into 4R:
Nasty looking, eh? But how realistic ...?
If I back off to idle, things improve somewhat ...
Then, disconnect all load to the rails, and we get the textbook result:
Interesting times ahead ...
Frank
Old 8th August 2012, 01:23 PM   #398
Sorry, ignore that figure of 82V I posted earlier for no load conditions. As Andrew pointed out, there was something awry there, and it turned out to be a combination of me being confused with a result taken under different conditions, earlier on, and not allowing sufficient time for the voltage to settle. A much more accurate value is a touch under 73.4V, so the transformer model is most likely to be of good accuracy ...
However, that doesn't change the main story that significantly, on the need for close to 20V "safety margin": 73.4V no load, 57V for full power, no clipping ...
Frank
Old 8th August 2012, 02:24 PM   #399
Banned
you can limit high ripple due to small Capacitance by using analog stabilisation or a Switch mode power supply
Old 8th August 2012, 05:09 PM   #400
gootee is offline gootee  United States
Here is the transformer model.
The only transformer models I have made are for transformers with around 22-30V outputs, since those are the only ones I measured (see measuremnt steps in model image).
So what is being used in the simulations is this model, but with a much higher input voltage amplitude than normal, in order to make the output voltage higher.
I just noticed, too, that the inputs and outputs are labeled. When identical labels are used in spice, those points in the circuit are joined, as if with a wire. So in the simulations so far, the secondaries of the two transformers have been in parallel. I will change that and see if it makes a difference, and will post a new overall model with the correction.
P.S. Frank, I lowered the input voltage to 321 V, to get an unloaded output voltage of roughly 71.136 Volts.
Tom
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
How do you calculate choke size in a power supply? Original Burnedfingers Tubes / Valves 25 5th January 2012 12:23 AM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
Copyright ©1999-2013 diyAudio
