Power Supply Resevoir Size
Old 7th August 2012, 12:39 PM   #381
R.I.P.
Originally Posted by OnAudio View Post
Here we go
http://www.diyaudio.com/forums/attac...ize-simple.png
This is the way I approach it now.
It is a filter.
This filter should not interfere with the action of the NFB.
This filter should not be the dominant roll-off of the bass frequencies. The input filter does that.
I set the pole of the reservoir capacitance at least a full octave lower than the input filter.
And I am back and looking quite brown compared to my usual complexion. Extended = 50days. I got back a little early. I was missing you all!
regards Andrew T.
Old 7th August 2012, 03:11 PM   #382
R.I.P.
Starting to catch up with the posts in this thread, missed out quite a few though.
Have you looked at local decoupling with low and high esr and remote reservoir, again with low and high esr? Then add in the esl effect of the cabling/traces?
regards Andrew T.
Old 7th August 2012, 03:27 PM   #383
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Welcome Back AndrewT, 50 days leave is almost retirement.
Kindest regards
Nico
Old 7th August 2012, 03:31 PM   #384
Nico Ras's Avatar
Originally Posted by Nico Ras View Post
Tom & Fred, ....
Sorry I meant Frank
Kindest regards
Nico
Old 7th August 2012, 03:35 PM   #385
OnAudio is offline OnAudio
OnAudio's Avatar
Originally Posted by gootee View Post
See the post after yours (i.e. post 372).
It shows that it's exactly as I've been saying all along:
The rail CURRENTS _ARE_ the signal, non-inverted, and they come from the capacitors.
Each rail does one polarity. So the currents look like a push-pull version of the signal.
The rail VOLTAGE just sags a little when the transistors open up, to let just the right amount of current out of the caps to create the load voltage.
Edit: It looks like the current for the negative rail cap (fC5) somehow got inverted, in the first image in post 370 (the 1600 uF version of the zoomed drum strike).
Tom
Yes there are some amplifiers that use this technique to drive the load
Old 7th August 2012, 03:39 PM   #386
OnAudio's Avatar
(And I still haven't even gotten to the decoupling caps, yet!)
Like a baby waiting for candy
Old 7th August 2012, 03:46 PM   #387
OnAudio's Avatar
Hi T was wondering about you
Old 7th August 2012, 10:46 PM   #388
fas42 is offline fas42  Australia
Banned
Sorry I meant Frank
No worries, Nico, I'm pleased that people are positive about where this is going!
Thanks,
Frank
Old 8th August 2012, 01:14 AM   #389
mightydub is offline mightydub  United States
Frank,
Good insight. That is the trade-space that needs to be quantified.
The voltage goes back up, a few seconds after that sim ends, by the way. But that points out a possible criterion for choosing the reservoir capacitance: They have to be large-enough to have enough charge to supply a sustained "short term" demand, i.e. at least until the next charging pulse, but also need to be small-enough that a) they don't drag the voltage too low for a worst-case burst between charging pulses, and b) they aren't so large that they can blast out a LOT more current than a charging pulse can supply, because then, if they're unlucky with the size and timing of the demand versus the size and timing of the charging pulses, they could just continue to force the rail voltage lower and lower. That's part of the equation we need!
This looks like a probability problem, too. What fun! (groan).
ESR and ESL play a role there, too, both those of the capacitors and those of the interconnects on both sides of them. And the transformer and rectifiers will probably need to be able to supply extra-big charging pulses, sometimes.
Tom (going to bed now)
I applaud the analytical approach, but isn't getting into probability taking things too far? My conclusions based on doing the engineering math, simulation, and listening are, to minimize the influence the power rail can have on the output, you need 3 things:
1) rails 20V higher (my rule of thumb, yours may vary) than the maximum output swing so that the rails can sag under load but still be comfortably above the maximum output voltage;
2) sufficient capacitance to handle the maximum specified output current (your earlier post showed how to calculate that.) Any more is of dubious benefit, and certainly increases cost. So do the math, figure out how many Farads you need, then apply whatever margin you like. My rule of thumb on the margin would be 20%, remember we're talking about peaks.
3) a design with high PSRR.
That gets you 95% of the way there. The next 4.5% is paying attention to low ESR in the capacitance bank and minimizing inductance in the power leads.
"We monitor many frequencies. We listen always. Came a voice, out of the babel of tongues, speaking to us. It played us a mighty dub… "
Old 8th August 2012, 02:17 AM   #390
Banned
I agree with you, mightydub, rules of thumb get you a long way down the path to the good stuff, top notch sound. But, in my experience, it's that last 0.5% where the real battle is, that's the area where everything measures beautifully, but it doesn't turn you on, vs. sound that makes all the question marks in your head go away ...
Frank
Power Supply Resevoir SizeHide this!Advertise here!
How do you calculate choke size in a power supply? Burnedfingers Power Supplies 28 19th July 2017 08:03 AM
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
