Power Supply Resevoir Size
Old 24th July 2012, 05:14 PM   #261
MagicBox is offline MagicBox  Netherlands
How about we create a special chopper loading module to test the buffering capabilities of an amp?
I'd construct it this way: An idle high impedance of say 10K ~ 100K load on the supply output, that, via a control signal can be switched to say 10 Ohm/10W using a MOSFET for a period of say 10mS.
Then, just record the transient response at the supply output closest to the load and see what effect all kinds of bufferings and different caps, inserted wires to get your parasitic L etc, have on the transient response.
The goal is to work towards a way of buffering that alters the voltage at the load node the least. Reduce spiking, reduce sagging. This will be a relatively easy way to find out how to create the best buffer distribution/arrangements.
Negative Feedback: The Need for Speed
Old 24th July 2012, 05:23 PM   #262
PChi is offline PChi  United Kingdom
The capacitors suggested in post #54 have an ESR specification of 16 mohm typical, 31 mohm maximum at 100 Hz / 20 degrees C. The impedance at 10 kHz = 30 mohm maximum so they are pretty low impedance at audio frequencies. It's going to require a large film capacitor to reach that low an impedance at 10 kHz.
Old 24th July 2012, 05:33 PM   #263
Well yes, but look at the cap you linked. Is that a power supply main buffer cap, or would that be your local decoupling caps on the board both at board entrance and close to the output devices?
That's what I mean, the local electrolytics won't be kingsize like a main smoothing cap, they are in the region of 100uF ~ 2200uF, and their ESRs are higher than that of an accompanying 100nF MKT.
Old 24th July 2012, 05:35 PM   #264
Could someone give me an indication of the self inductance of say an 8 inch length 2.5mm2 wire? 20 years ago since I last calculated such stuff by hand, bare with me
Old 24th July 2012, 05:40 PM   #265
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Power Supply Resevoir Size
negligible?
200 nH ?
Old 24th July 2012, 05:41 PM   #266
I think that it would be the power supply main buffer cap. I would expect local decoupling on the amplifier PCB as well. At 10 kHz the reactance of a 100 nF capacitor is 159 ohms so the audio current is going to come from the power supply main buffer capacitor.
Old 24th July 2012, 05:42 PM   #267
Originally Posted by tsiros View Post
negligible?
I don't know if it would be neglible when talking the size of currents in a decent amp. The L could be just high enough to 'choke' the T=0 current and prohibit initial demand. I was about to put a simulation together of a full rectified supply with buffercaps and ESR simulation, along with the chopper circuit to view the transient response. I wanted to model the supply wire in there too.
Old 24th July 2012, 05:47 PM   #268
The reactance (X) doesn't matter, it's not in series with the load, you have to view it as an ideal supply with an internal source resistance equalling the ESR paralleled to the main supply. Think 'shortcutting' a charged cap, that's a HUGE T=0 current and has nothing to do with its frequency dependant impedance.
Amps(T0) = Vcap/ESR
Additional info
Old 24th July 2012, 06:01 PM   #269
forr is offline forr  France
forr's Avatar
PChi,
I think that your waveform distortion on the positive supply is voltage drop caused by the rectifier current.
It's either due to where the Oscilloscope probe is connected when the extra voltage drop is due to the resistance of the wire and connections (What does the waveform look like when the Oscilloscope probe tip and ground are connected directly to the capacitor terminals).
Or the electrolytic capacitor ESR is rather high.
I've done this experience with different caps (I checked them first with a tan-delta meter), transformers, rectifiers and connections of the probes.
Each time, the phenomenon happened for high values of capacitor.
It has been repeatable for me but I do not exclude an error in my procedure.
Maybe somebody could do the same test and show his findings,
Old 24th July 2012, 06:12 PM   #270
tsiros's Avatar
i doubt a 200nH inductance would have any significance
current of what size are we talking about here?
Power Supply Resevoir SizeHide this!Advertise here!
How do you calculate choke size in a power supply? Burnedfingers Power Supplies 28 19th July 2017 08:03 AM
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
Copyright ©1999-2017 diyAudio
