Power Supply Resevoir Size
Old 19th April 2013, 08:26 AM   #1951
HiFiNutNut is offline HiFiNutNut  Australia
Originally Posted by 1audio View Post
There is also some inductance in the transformer. You can short the primary and measure the secondary's inductance at 120 Hz and 1 KHz to get a number to add to the model. I would definitely add something like 100 mOhms for the AC source at a minimum.
I have measured and included 29uH leakage inductance.
Old 19th April 2013, 08:26 AM   #1952
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
To reduce the reading error, check the resistance between the two 50V ends. Then include double this value in your sim because its more likely than not the trafo designer did a fairly decent job of optimizing the pri/sec resistances
As Demian suggests you can go on to include leakage inductance (leakage goes in series with the primary) though the leakage inductance is very unlikely to significantly reduce your peak currents, particularly for a toroid which usually have very low values.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 19th April 2013, 08:30 AM   #1953
abraxalito's Avatar
Originally Posted by HiFiNutNut View Post
So the combined AC source impedance is 0.12R + 1.4R = 1.52R?
No - I was just estimating what the primary resistance would normally be from your secondary measurements and the turns ratio. To include any impedance on the primary side as a secondary parasitic you must transform it by the square of the turns ratio, not use it natively
Old 19th April 2013, 08:35 AM   #1954
Good idea. I just got back to the bench and measured again and confirmed that each of the two primary windings has 0.12R and the primary has 2R.
Old 19th April 2013, 08:37 AM   #1955
abraxalito's Avatar
I assume then you meant 0.12R per secondary so your total secondary resistance is 0.24R. So that's the secondary part of the impedance - the primary part becomes 2/(2.4)^2 = 0.35R for a total simulation value of 0.59R.
Old 19th April 2013, 08:59 AM   #1956
Thanks a million. That has really been a great help!
There is one thing I am not so clear. I understand now how the 0.59R is derived. But since this impedance is seen by both the two opposite +V and -V rails, when modelling one rail only should the impedance be 0.35R / 2?
Old 19th April 2013, 09:03 AM   #1957
abraxalito's Avatar
Makes sense to split the total secondary resistance into two halves yes - 0.3R per side ought to be close enough.
Old 20th April 2013, 06:46 AM   #1958
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by AndrewT View Post
I have not made up my mind which is better. I have amplifiers of both types. Fused supply rails and unfused supply rails.
I have several pieces of information on that, and a question too.
On my LM1875 projects thread, it is popular for constructors to ask "why did my amp blow up?" along with a photo of an amplifier the size of a thumbnail powered by a transformer the size of a teapot. Mystery solved! This needs fuses added.
If the rails fuse blows, one rail is output to the speaker or if the amplifier blows, one rail is output to the speaker. So, there's no difference to the speaker, but fuses might save the amplifier.
Although crude, fuses could be informative and educational, and might succeed where transformer sizing directions have failed. Approximately, about 2% of constructors have used appropriate current on that particular project. May I assume that the success rate of fuses could do better than ~2%?
Question:
What size and type fuses should I put on the rails for one chip LM1875 amplifier board?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 20th April 2013, 08:15 AM   #1959
Dan,
put a T fuse in the mains supply to the primary of the transformer.
Ensure the rating is for close rating or lower.
i.e. two 60W channels running from a 160VA on 115Vac needs a fuse of T1.4A, or smaller. The nearest lower value is T1.25A.
The transformer will probably not start reliably with this size of fuse. Use a soft start with 60r to 100r as the current limiting resistor.
regards Andrew T.
Old 20th April 2013, 12:44 PM   #1960
Now back to the topic, i.e. Power Supply Reservoir Size.
The way I do is that I check the PSSR of my amplifier and try to come up with a power supply PSSR such that the two PSSRs combine together to produce at least -110dB from 20Hz to 10MHz. From there I can determine how much ripples the power supply can tolerate when the maximum current is drawn then determine the Reservoir Size.
Would -110dB be good enough for you? What is your target?
Power Supply Resevoir SizeHide this!Advertise here!
How do you calculate choke size in a power supply? Burnedfingers Power Supplies 28 19th July 2017 09:03 AM
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 05:12 PM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 03:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 06:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 7th December 2007 12:50 AM
