Power Supply Resevoir Size
Old 31st March 2013, 07:33 PM   #1881
simon7000 is offline simon7000  United States
Note the unloaded noise. The toroid uses grain oriented steel. I think that makes a difference. But also check Tamura I think they make a flatpack.
Old 31st March 2013, 10:36 PM   #1882
Demian
http://www.tamuracorp.com/clientuplo...PF24series.pdf
Old 31st March 2013, 10:41 PM   #1883
1audio is offline 1audio  United States
Thanks. I wish they had a way to specify acoustic buzz. I'll get some samples and try them.
Demian Martin
Product Design Services
Old 31st March 2013, 10:48 PM   #1884
I have trouble believing those aren't defective. My samples are only a few months old.
Old 31st March 2013, 11:52 PM   #1885
I have more than one. I'll check the others. We will be on the phone to Signal first thing tomorrow.
Demian Martin
Old 2nd April 2013, 12:22 AM   #1886
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by Fob View Post
I think the question is more complicated than it looks. Depends of PA topology, PS type and so on. I'll give an example.
There was japanese patent from '70s that prevent voltage drop to driver stages. The sound quality improvement is significant. There is more issues. No one rectifier 'love' big capacitors. . . .
You can connect an LM1875 or LM4702 at the spot marked driver stage, and all of the diodes sturdy schottky.
In either case, the high current hookup is the speaker return cable going to the 0v tap on the far left side of your diagram, right at the large caps.
D1 and D2 have prevented C1 and C2 from slowing down C3 and C4. So, by using the diodes, the decoupling has worked.
Kudos!
Yay for not driving with the parking brake on!!
It answers Nico's question at post1, post8, post9 about large capacitance sounding dull. Yes, one possible answer is to insert a diode (or a regulator could be used for a more orthodox appearance). So, if you want the fresh sound of small caps, you insert a really creative passive or an active or in fact use small caps.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 2nd April 2013, 07:05 AM   #1887
rfj5106 is offline rfj5106  United States
I am building a power amp using a Meanwell 48V @7.5 amp power supply to power 'Sure Electronics' Digital Amplifier board rated at 300 wpc @ 4 ohms. I expect this rating is probably optimistic but how much capacitance would be recommended for this combination?
Richard Jenkins
Old 2nd April 2013, 07:21 AM   #1888
Default "Safety-Sized" transformer
With the source of these pulses the bridge rectifier output, shorter length pulses = less power.
Originally Posted by gootee View Post
But for our simple case, generally, the larger the reservoir capacitance is (or the lower the ripple p-p voltage is), the shorter the pulses are.
So, bigger capacitance = less power. Yes, that's bound to happen when the transformer current, is sized during transformer purchase, below output device capacity, as protection. That's a good thing except. . . That's when it is possible to overwhelm the transformer with too much capacitance and incur that muddy "parking brake" like problem.
Like this:
When the transformer is near maxed out, quite busy both running and smartly protecting the audio amplifier, there's a limited amount of capacitance that it could charge brim full while in this condition.
What is?
Can we relate a transformer in strained condition to a chart with VA and max capacitance?
I end up considering Parallel output devices and monobloc/dualmono builds in order to get enough transformer to charge the power board, without enough transformer to overwhelm the outputs/fuses. So far, that consideration works, but sizing the power board perfectly is still not easy.
Old 2nd April 2013, 07:32 AM   #1889
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
As much as you can spring for I'm currently using a Meanwell 18V supply for my chipamp (which is an analog one, not classD) and I have a 4 pole LC filter to remove as much as possible of the switching frequency (which I think is around 40kHz). With SMPSUs and classD amps the impedance of the capacitors is at least as important as the total value as they generate huge amounts of HF hash. So be sure to use low ESR types and parallel them up.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 2nd April 2013, 07:45 AM   #1890
R.I.P.
Originally Posted by danielwritesbac View Post
With the source of these pulses the bridge rectifier output, shorter length pulses = less power. ............
What does this mean?
Where did it come from?
Please answer in plain english.
regards Andrew T.
Power Supply Resevoir SizeHide this!Advertise here!
How do you calculate choke size in a power supply? Burnedfingers Power Supplies 28 19th July 2017 08:03 AM
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
