Power Supply Resevoir Size
Old 28th March 2013, 02:36 PM   #1861
R.I.P.
22degrees is much more realistic.
60 degrees is not what we use/find.
regards Andrew T.
Old 28th March 2013, 03:51 PM   #1862
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Hi all,
sorry if it is already answered.
I don't want to read the whole thread
Is there any difference ideal capacitors size between dual secondary dual diode bridge
and center tap transformer with single diode bridge?
Thank you, I wish you happy
peace & G B U
Old 28th March 2013, 04:45 PM   #1863
DF96 is online now DF96  England
It depends. An extra diode drop may or may not make a big difference, depending on how much spare voltage you have. To understand the issue you will need to read the thread. Sorry!
Old 28th March 2013, 07:10 PM   #1864
simon7000 is offline simon7000  United States
I did promise some pictures.
The first is a 24 VCT flatpack transformer driven two diodes into a capacitor (10,000 uf) and 50 ohm resistor. Note the unbalanced peaks which can indicate diode mismatch or unbalanced windings.
The second is the same circuit with only a 470 uf Capacitor doing the filtering and a toroid transformer with more than 10 times more current capability.
So you can get an idea of the maximum and minimum charging times. Note on the toroid it is the back side that lingers!
File Type: jpg Current Pulse Torroid 12V 470 uF Filter.JPG (93.1 KB, 218 views)
Old 28th March 2013, 10:48 PM   #1865
First one dominated by transformer resistance; second one dominated by transformer inductance? One could imagine some ringing superimposed on the charging pulse in the second one. Just a guess.
Old 29th March 2013, 07:44 AM   #1866
alayn91 is offline alayn91  France
alayn91's Avatar
Hello,
Why is the scale voltage only 20mV ??
Regards.
Old 29th March 2013, 08:18 AM   #1867
Fob is offline Fob  Bulgaria
I think the question is more complicated than it looks. Depends of PA topology, PS type and so on. I'll give an example.
There was japanese patent from '70s that prevent voltage drop to driver stages. The sound quality improvement is significant.
There is more issues. No one rectifier 'love' big capacitors. The diode recovery can inject significant spikes in the rails. Sometimes the 'shunt 100nF' to the main electrolytes are crucial ... so on.
Other things. If you have 'magnificent' sound in 75% from rated power is beter that 'good' sound in all power range ....
Old 29th March 2013, 10:34 AM   #1868
R.I.P.
I have an apology.
I was considering only 50Hz supplies.
Simon has shown the data for a 60Hz supply.
regards Andrew T.
Old 29th March 2013, 12:49 PM   #1869
Originally Posted by alayn91 View Post
Hello,
Regards.
We are measuring current! The scope is calibrated in voltage it is a small resistor of .1 ohms in the ground leg we are viewing.
Old 29th March 2013, 11:07 PM   #1870
Gootee I didn't mean to drive you off. I was impressed by your math. Keep up the good work.
Power Supply Resevoir SizeHide this!Advertise here!
How do you calculate choke size in a power supply? Burnedfingers Power Supplies 28 19th July 2017 08:03 AM
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
