#1801 |
The LT Spice model's considerably clearer than the other documentation, as it were; I'll take a closer look when I get some time. Thanks!
#1802 |
The spreadsheet is, of course, fully documenting all of the math, if you look at the cell formulas and the VBA code.
In LT-Spice, I made the transformer model MUCH more useful by making it a component, with a symbol, and by making its parameters settable from the main circuit's schematic, where it was used. To do that, I put something like Vsb={Vrms_setting} Ssb={VA_setting} fb={mains_freq_set} Vpb={mains_rms_set} in the PARAMS line in the box that pops up when I right-click on the symbol I created for the transformer. Then I can set the params (that appear in the { }s, above) in the main circuit's ".param" spice directives, and can use them in sweeps! It's been QUITE useful! And if you have a variac, it's quick and easy to measure what's needed in order to make the model for a different transformer. You can download a .asc file for a slightly-older version of the transformer model, from somewhere in this thread. And there should also be a zip file here that even includes the symbol for the transformer, etc. Last edited by gootee; 15th March 2013 at 02:07 AM. |
#1803 | |
the consensus is general on this statement ? What is the problem with too much capacitance in the PS ? Actually the best amps around have huge capacitance Some manufacturers even offer a capacitance upgrade for their amps Thanks for any explanation. Kind regards, gino Last edited by ginetto61; 16th March 2013 at 05:33 PM. |
#1804 |
Maybe there could be a problem if the transformer was too small. It needs to be able to recharge all of the caps and maybe also supply part of the music signal, during the short times when the rectifiers turn on. I can't think of any reason that more capacitance would be bad, especially if it had low-inductance connections. It should give a lower impedance, which should make its response faster, not slower. The signal is current, not voltage. The larger RC time constant slows the voltage droop but that's a good thing.
#1805 |
The larger the reservoir capacitance the greater the cost and complexity, both in and of itself and in the addition of components such as soft start circuits. Using large cap banks as a workaround for poor PSRR by minimizing ripple in a linear supply also reduces the diode conduction angle in the bridge, which tends to degrade both reliability and power factor. For DIY these aren't often significant concerns, but it is a bit silly to stack up 100,000uF per rail when you can get the same job done with a 50 cent regulator and 10,000uF per rail.
From a sound quality perspective, the narrower the conduction angle the broader the bandwidth of the ripple. So, in addition to there being less ripple, throwing cap at the problem results in spreading the charging energy over a larger number of mains harmonics, reducing their audibility. In an amp with insufficient PSRR to be transparent to the supplies (which would be, um, a lot of them---typical designs are in the 70dB range whereas 100+dB tends to be desirable) this means changing caps makes audible changes in the amplifer's tonal qualities. To answer Gino's question, some people like more supply dirt in their music, others like less. |
#1806 |
Use a ripple filter instead. Less costly and a lot cheaper!
#1807 | |
If one thinks of creating a system like designing a bridge then one has a much better chance of getting it to work right. Every component is linked to everything else in some fashion, and just using some "fashionable" technique, or "impressive" idea that someone reckons is the go, is not going to cut it. Which is a long-winded way of saying that a supply should be both low ripple and "fast". To do the two at the same time, correctly, is just an engineering issue ... Frank |
#1808 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
To return to gino's question, I suspect the problems arising from higher cap values only apply to caps fed from mains freq rectifiers - the charging pulses become shorter and richer in harmonics and are more likely to couple into other parts of the circuit. At these higher freqs, the impedance of the cap becomes ESR limited. The solution to that is paralleling many smaller ones and adding some series L along the way. I rather suspect then that there's no upper limit on improvement by adding capacitance, just increasingly smaller returns for the outlay.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#1809 | |
I think you probably meant to type ESL at high frequencies rather than ESR, or does high mean kHz in this content? Not sure why one would want to add ESL; most regulators land in the uH range on their own. |
#1810 |
'High' meant 'above 1kHz' in this context - I agree at even higher freqs - say above audio then ESL becomes dominant. I added the explicit inductor because I suspected (though didn't measure) that the regulator had stability issues without. I have rather a lot of very low ESR ceramics on my supply too...
Yes the rising output impedance of the reg looks like an inductor - back of the envelope of the order a few hundred nH.<edit> Just worth mentioning - some incredibly large (hundreds to thousands of Farads) caps are available nowadays. They're not useful because their ESR is too high. They're very limited voltage (2.5V typically) so you have to put quite a few in series by which time the ESR kills them as audio band decouplers.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart Last edited by abraxalito; 17th March 2013 at 01:41 AM. |
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
