#1711 | |||
Are you thinking that something more like 330 uF would be about right? Quote:
#1712 |
You fellas are really going to town there ... in my playtime i went with good ol' FCs, 1200/50. Availability, ripple current, costing meant these were the best bang for the buck for me, I went the rounds many times looking at options. Didn't use as many caps, regulated feed took care of a lot of the sag.
And, chopped off the legs of the chip amps to give me just enough metal to solder to - every nH is precious ... Frank |
#1713 | |
I used 8 Ohms and 4 Ohms. It's just an example, basically. The point, really, is that you can set the ripple (and the load resistance) to whatever you want and then calculate what you need to do to achieve that under worst-case (or any other) conditions. I guess I just like developing equations again, for a change. But it's much easier and more-flexible to just simulate the whole power supply in LT-Spice. Then you can do things like have it automagically sweep parameters over ranges and see the resulting series of plots, for example. With equations, it's probably difficult for others to keep in mind what ASSUMPTIONS and conditions I have set, too. I spent some time figuring out what "worst case" should be and usually that is embodied in the equations. (I state them, usually, but it's still hard to keep in mind, maybe.) But it's probably different than what most people are accustomed to seeing, as far as C values. I usually prefer to meet the ripple spec while driving DC through the load, at the max rated peak values, for example. That way, I "KNOW" that it's truly able to work how I want it to, with the worst worst case. Most people assume a sine wave. But what if there are two? And in reality there might be dozens or hundreds simultaneously, especially if you consider all of the Fourier components of anything non-sinusoidal, which includes all music. With one piece of music someone came up with, instead of one sine peak grazing the peak value periodically, you got more and more and pretty soon there was almost always a wave touching the peak rated output value. So it might be more like a square wave, with its horizontal parts at the peak rated voltages. But that's just DC, part of the time. So "all of the time" is an even better "worse". Then I usually also look at what the resulting configuration will do at NORMAL listening levels. Peak rated level performance is good to design to. But I never ever listen at that level. If I design for the really-worst worst-case, though, everything is usually surprisingly good at listening levels. Last edited by gootee; 31st January 2013 at 04:28 AM. |
#1714 | |
I will at least make the pins as short as possible, like you did. (Gotta get to bed. Early meeting tomorrow.) |
#1715 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Seems to me as the inductance of the paralleled caps isn't going to be the major issue, by at least an order of magnitude that to do this properly the chipamps should be paralleled up too?
@Tom - I'm settling on whatever's easy to get but below 470uF yep. Most recently 390uF but yet to build with those.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart Last edited by abraxalito; 31st January 2013 at 04:52 AM. |
#1716 | |
![]() I used a very long, narrow, finned black heatsink, standing upright - had the best thermal rating for the size, and money. Hence chip upright, and circuit horizontal. Obviously awkward in normal situation, but I was using these effectively to create active speakers, was on a slab of material against the back of the carcase. Frank Last edited by fas42; 31st January 2013 at 04:58 AM. |
#1717 | |
Frank |
#1718 | |
Suggestions on the decouple value at the board .....?
A man should look for what is, and not for what he thinks should be. -Albert Einstein |
#1719 |
The panasonic FC are definitely a best buy, and so are the FM if you can use their limited value range.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#1720 |
What about the sonics, FM or FC ...?
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
