#1571 |
Connect the HF decoupling together.
Connect the MF decoupling together. Connect these two and call them Power Ground. Connect the output Zobel to Power Ground. Connect Power Ground to Main Audio Ground. Connect Speaker Return to Main Audio Ground. This, as far as I can see, is the best way. I don't have H.Ott's book, nor articles so can't compare my suggestion to his bible, but I suspect there is little, if anything, that is fundamentally different. Fas, an opamp does not have internal local decoupling. Instead we fit external local decoupling. They get connected just as described above. I consider opamps and chipamps and Power Amplifiers as the same thing when I try to layout my wiring/traces. They all work to the same physical laws. Does that help? I have downloaded the link to Ott and will read it. Can we have a subsection somewhere in the Forum to store a compendium of really useful articles. eg a link to Jung's archive, a list of Ott's openly published works/articles. There are many other links, or pdfs that can be included. Last edited by AndrewT; 8th November 2012 at 10:45 AM. |
#1572 |
but, such a device does not by itself solve the peak current demand problem.
The emf driving the current and the capacitor demanding the current in response to the emf will try to charge the capacitor in one quarter cycle. The SS relay timed to close at zero crossing will still suffer an enormous current pulse. One must consider the components in the charging circuit and decide what the one shot peak current can be to allow all components to have a long lifetime. That peak current may be limited by some slow charging circuit. If one decides that a slow charging circuit is required, it can be as simple as an added resistance in the charging circuit. Last edited by AndrewT; 8th November 2012 at 10:33 AM. |
#1573 | ||
HF/MF decoupling? Thanks for your patience, Stefano |
#1574 |
HF decoupling = High Frequency = ceramics or similar with trace/lead lengths <20mm round trip route.
MF decoupling = Medium Frequency = electrolytics or similar with trace lengths >>20mm round trip route. Do you really need a drawing to implement that set of suggested instructions? |
#1575 |
Thank you Andrew,
I asked because I seem to remember a drawing by mike on another thread sharing the opportunity of placing a resistor between Power and Main Audio grounds, but I'm not so sure, and guessed you probably were referring to something similar. I'm too lazy a fellow. No, no need for you to draw something for me. Thanks a lot Last edited by seppstefano; 8th November 2012 at 10:59 AM. Reason: drawing found |
#1576 | ||
Frank |
#1577 |
Chipamps and Power amps have an on PCB set of decoupling capacitors. Since these are on board I think of them as "internal" to the amplifier. They are there by design and result in a Power Ground Pin/Tab/solder pad.
But an opamp does not have an internal set of decoupling caps. Instead we add them externally. The junction of those decoupling caps is the Power Ground (PG) and that PG is outside the opamp. We have created a PG just like a Power Amplifier, but in the opamp it is "external" whereas for the PA it is "internal". The two systems are equivalent, all that varies is the actual location of the decoupling and PG pin. The Main Audio Ground (MAG) is the "point" in space where all the circuits pick up their reference voltage. I choose to locate it at the centroid of: Speaker terminal, Input terminal, PG & PSU Zero Volts. NOTE !!!! the MAG is never coincident with the PSU Zero Volts. By placing the MAG at the centroid, all the wires coming from various parts of the amplifier are kept to reasonably short lengths. No single wire is excessively long, except maybe the PSU Zero Volts link. The PSU may be the furthest from the centroid if the decision is taken to maximise the transformer to amplifier distance within the constraints of the chassis. Last edited by AndrewT; 8th November 2012 at 11:55 AM. |
#1578 | |||
As far as I can see my suggested connections follow Ott's recommendations in all details. There are certainly no fundamental differences between Ott's and mine. If there were I would look at how to modify my method. All my suggestions have been developed without sight of Ott's papers and virtually all the information came from posts on this Forum. It would appear that there are many Members posting here that know what to do, I am simply the messenger, you Members are the Source. It is just that you get outnumbered by the ill-informed Members who post rubbish. Before I close, Ott makes numerous mentions of ground planes in that paper. Nowhere in that paper does he state, nor show that a Flow and Return pair cannot perform as well as a ground plane. I would suggest that his paper although based on Ground Plane implementation is actually an argument for not using a Ground Plane. Maybe his other papers show otherwise. As an example look at ex1 and fig5. Here a pair of wires or a pair of traces would perform the same as a coax and none of those require or benefit from a connection to the ground plane at the load end. Except where he considers the case of parasitics that become significant enough to bring the VHF effect down into HF. That will effect the HF performance. I'm thinking here as HF = 100kHz to 10MHz. Comments? Last edited by AndrewT; 8th November 2012 at 02:12 PM. |
#1579 | |
Thanks for the nice job. Looking forward to your findings
www.harrisonaudiolabs.com |
#1580 |
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
| Page generated in 0.39574 seconds (100.00% PHP - 0% MySQL) with 10 queries |
