#1541 | |
It may not be an issue, but don't elcos also require a DC bias to achieve full ratings?
regards |
#1542 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
As far as I'm aware, my LCR (Tonghui TH2817B) determines the overall impedance by measuring the resistive (in phase) component together with the reactive (quadrature) component. Its probably using a standard chipset not too dissimilar to this one: http://www.cyrustek.com.tw/spec/ES51920.pdf
I've since played around some more and found that the 4 wire probe set I was using doesn't give the most consistent results, so I've cross-checked with a more traditional static test fixture. The readings were similar at lower freqs but this refused to give a capacitance reading at 10kHz measurement frequency, implying the 10mF cap looks to be near as damn it a short. At 20kHz its overall inductive, reading a negative capacitance value ![]() I'm not sure if DC bias is required, however my meter operates with a predictable polarity as the leads are clearly marked +(red) and -(black).
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#1543 |
This capacitance variation anomaly sounds like a methodology problem.
What if you select a frequency and appropriate resistor for the F-3dB frequency and simply measure the voltage across the cap and the resistor? Then change the frequency and select a new appropriate resistor value and measure again. Yes the Capacitive impedance at 20kHz is very low. The series resistor must also be very low for the two measured voltages to be near enough equal. That low value of HF impedance is confirming that the capacitance is still high at the 20kHz test frequency. Last edited by AndrewT; 30th October 2012 at 10:17 AM. |
#1544 |
Reduced capacitance at higher frequencies may be a consequence of the deep foil etching used to make modern small-size big-value caps. The reduction may be as much due to the resistance of the foil as its inductance. Interestingly, this could mean that new electrolytics are worse than an old-but-fresh original component (if such a thing could be found).
In many cases it doesn't really matter, provided that the actual net impedance remains low. You could argue that if 10000uF is required at 20Hz, then only 10uF is required at 20kHz to do the same job. I know it's not quite that simple, but it may mean that if 500uF at 20kHz is all the cap can deliver then it is still plenty enough to do the job. |
#1545 | |
In terms of current delivery I agree with your reasoning that at higher freqs, less capacitance is needed, all other things being equal. However amp PSRRs generally reduce at 20dB/decade so in PSRR terms we'd need to maintain the same rail capacitance above the PSRR corner freq to have an error term (arising from the finite PSRR) which was flat with frequency. @Andrew - yes the resistor has a very low value in your suggestion. Take 10mF and a -3dB freq of 10kHz, it gives R = 1.6mohm by my reckoning. This is way below the ESR of the cap.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart Last edited by abraxalito; 30th October 2012 at 10:41 AM. |
#1546 | ||
Something to try if you have never done it before is to explore, either by calculation simulation or measurement, the effect of series to parallel conversions. e.g. put a low value resistor in series with a cap, then another cap in parallel with that. See how the toal impedance varies with frequency, and where the effective resistance peaks. Even a simple circuit like this has counter-intuitive behaviour. The resistance has most effect at mid-frequencies, not high or low frequencies. You can even find values which mean that increasing the internal resistor means the external measured resistance goes down! Quote:
#1547 | |
Are we into Wheatstone territory? Is it Member Conrad that has a website showing how to measure capacitance and esr etc? Last edited by AndrewT; 30th October 2012 at 11:04 AM. |
#1548 | |
#1549 | |
locating the HF decoupling and the MF decoupling correctly such that each can perform as expected and the LF decoupling (= smoothing?) can be almost anywhere. LF decoupling can and should be right next to the rectifier/s not necessarily on the PCB. |
#1550 |
Here I have to make a confession - I can't quite see the point of local (HF) decoupling when the current loop being decoupled is much larger than the PCB itself. Perhaps I'm missing something though... I'd always thought that local decoupling was to keep the current loop small, but with an audio chipamp we've a relatively huge loop area compared to the circuit under consideration. Even if we assume we're decoupling to star earth and the speaker return comes back there too, that's not generally on the amp PCB so there's appreciable inductance in the wire back to star ground. That inductance seems to me to be in series with our HF decoupling cap rather nullifying its moniker as 'HF decoupler' no?
| Valve power supply - How to size transformer? | SanderW | Power Supplies | 25 | 4th January 2013 04:12 PM |
| How do you calculate choke size in a power supply? | Original Burnedfingers | Tubes / Valves | 25 | 5th January 2012 12:23 AM |
| power supply bypass cap size | BigE | Power Supplies | 11 | 5th July 2011 02:59 PM |
| Power Supply Case Size | diymixer | Power Supplies | 1 | 10th October 2010 05:47 AM |
| What size power supply should I get for repair work? | spooney | Car Audio | 3 | 6th December 2007 11:50 PM |
