Power Supply Resevoir Size - Page 154 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th October 2012, 04:39 PM   #1531
DF96 is offline DF96  England
Originally Posted by danielwritesbac
Do amplifier topologies vary widely on power supply requirements,
Apart from PSRR the critical feature (for reservoir cap size, the topic of this thread) is voltage drop in the output stage (including any emitter resistors), especially when compared with the difference between off-load rail volts and required peak output volts. If you increase the voltage drop then you have to increase the cap size so the supply voltage droop under load is reduced.
Old 27th October 2012, 04:29 PM   #1532
Default assumptions
How valid are the claims below ?
Old 27th October 2012, 04:51 PM   #1533
they are unlike any I can recall seeing before.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th October 2012, 06:12 PM   #1534
Both appear to say nothing of any value. The first one appears to confuse core flux with winding temperature issues. The second one is insufficiently coherent to be criticised. Where did you find them?
Old 28th October 2012, 02:25 PM   #1535
danielwritesbac's Avatar
I think the second attachment of post 1532 is showing a futile attempt of continuing to pile on more capacitors to the too small transformer. That is counterproductive. Some of Tom's spreadsheets listed those conditions as impossible, invalid, or a negative number.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 28th October 2012, 05:27 PM   #1536
alayn91 is offline alayn91  France
alayn91's Avatar
Hello,
And where these assumptions are coming from ??
Old 29th October 2012, 12:19 AM   #1537
fas42 is offline fas42  Australia
Banned
Though, piling on more capacitors, of the right type and in the right area is highly productive. Because this markedly reduces, shall we call it, micro fluctuations ... higher frequency disturbances of the voltage rails, the sort of thing that loves jumping around inside a circuit via all the parasitic capacitances that are part of real components. If you're into "micro detail" in your sound then this just may be part of the answer ...
Frank
Old 30th October 2012, 04:01 AM   #1538
gootee is offline gootee  United States
Frank
And in my spreadsheet, the capacitances are what would have been _required_, in order to have no possibility of even a tiny bit of clipping. It had nothing to do with adding extra (or too much) capacitance to an already-OK situation. It only meant that the cases being considered were either impossibly underpowered, or almost so.
Old 30th October 2012, 04:14 AM   #1539
AJT is offline AJT  Philippines
AJT's Avatar
has anybody compared caps with varying ESR's as against mere cap values?
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 30th October 2012, 04:33 AM   #1540
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I was looking at some caps I pulled out of a poweramp I'm currently modding yesterday on my LCR meter and took a bit more trouble than normal to understand how the impedance was changing with frequency. They're 10,000uF/50V a fairly typical value for a mid-range amp.
What I saw was though the capacitance was close to the sticker value at 50Hz it fell at higher measurement frequencies. Here are the values I jotted down in my notebook:
50Hz 9,535uF
1kHz 8,035uF
10kHz 1,530uF
20kHz 495uF
Anyone else come across this? I tried a couple of other brands (Rubycon, Elna), similar results. The capacitance is down to 5% of its marked value at 20kHz, seemingly due to internal inductance which, in turn varies with frequency. I calculate about 0.5uH @ 1kHz down to 120nH at 20kHz.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 05:12 PM
How do you calculate choke size in a power supply? Burnedfingers Tubes / Valves 25 5th January 2012 01:23 AM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 03:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 06:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 7th December 2007 12:50 AM
Copyright 1999-2017 diyAudio
