Power Supply Resevoir Size
Old 23rd October 2012, 05:36 PM   #1521
DF96 is online now DF96  England
Originally Posted by OnAudio
Later there was a science fiction piece that went un answered
The diagram in your post 1135 was certainly fiction, but not much to do with science, and it was not unanswered: I pointed out the flaws in the bottom of post 1138.
The misunderstandings in your post 785 might not have been answered, though.
Why drag them up now, when they are best forgotten?
Old 23rd October 2012, 06:13 PM   #1522
OnAudio is offline OnAudio
OnAudio's Avatar
Thank you DF96. A very simple circuit would be a passive first order low pass filter. What happens when you increase the load resistance ?
onaudio.herokuapp.com
Old 23rd October 2012, 09:27 PM   #1523
Not certain about relevance, but it would depend on whether it was CR or LR.
For CR low pass increasing the load resistance increases attenuation and raises corner frequency.
For LR low pass increasing the load resistance does not affect attenuation and lowers corner frequency. So what?
Old 23rd October 2012, 09:53 PM   #1524
OnAudio's Avatar
Thank you DF96. Does this in any way affect transient response ?
Old 23rd October 2012, 10:13 PM   #1525
Just to clarify, by 'increasing the load resistance' I actually meant 'applying a greater load' i.e. reducing the numerical value of the load resistance. Sorry for the confusion.
My point is that CR and LR filters behave in opposite ways as the R value changes. I seem to recall confusion on this might have been the original issue.
Old 26th October 2012, 02:27 AM   #1526
OnAudio's Avatar
What would be the instantaneous max VA for a 300VA transformer ?
Old 26th October 2012, 04:06 AM   #1527
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by AndrewT View Post
Did you mean to point to post1501? Twice?
In this case, it would be a lot more reliable to type the post number.
Here's the parameters:
Intra-thread links to attachments works fine,
Inter-thread links to attachments work fine,
intra-forum/inter-thread links (between two threads) links to posts work fine,
but intra-thread links (within same thread) to posts are hit or miss.
I also got 1501 twice.
For a large project, here's a workaround:
Discussion, simulation and testing on the big "main" thread, versus soldering and shopping on the little "build" thread.
A build thread is a "summary" concept and post 1 is re-edited in reaction to new questions in order to create more effective documentation. To avoid intra-thread links (that can miss the target), the links must refer to a different thread, which is the longer main/development thread. A build thread (a summary) can be started as a collection of notes and links all in post 1 of a new thread (post 1 has forever edit), and that can be reorganized into something cohesive after the task of reading through and making notes on a long thread is completed. The majority of build thread content is actually posted on the main thread, and, in that case, the links work.
Meanwhile, back on topic. Do amplifier topologies vary widely on power supply requirements, or is that one unusual? The low bass power is generous and audio resolution is seemly with just 160va and 4400uF per rail for my circlo monobloc. However, my other amplifiers seem to need more voltage, double the current and triple the capacitance before achieving a similar performance. Why?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 26th October 2012, 05:54 AM   #1528
fas42 is offline fas42  Australia
Banned
A simple answer would be the the PSRR of the amplifier circuit, the ability to ignore the fluctuations of the voltage rails, especially at high frequencies. Real supplies with minimal specs inject a lot of rubbish into the amp, and there are dramatic differences in the way the different circuit configurations react. So, if you're not sure, build a Mack truck of a power supply ...
Frank
Old 26th October 2012, 08:00 AM   #1529
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
how hot can you allow your traffo to become?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 26th October 2012, 10:04 AM   #1530
R.I.P.
instantaneous could be 100ms or 10ms or 1ms or 100us or 10us or 1us or more accurately an instantaneous moment that has no measurable time period. It is an instant.
If the period is very short there is little time for any heating to occur.
Then there will be no measurable increase in temperature.
For very short term overloads, I'd suggest 10times VA is acceptable. Transformers are very tolerant of short term overload.
regards Andrew T.
Power Supply Resevoir SizeHide this!Advertise here!
How do you calculate choke size in a power supply? Burnedfingers Power Supplies 28 19th July 2017 08:03 AM
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
