Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th September 2012, 07:42 PM   #1161
DF96 is offline DF96  England
You won't find many textbooks in the fiction section.
Old 14th September 2012, 07:53 PM   #1162
OnAudio is offline OnAudio  United States
How about a book on alternative technology in the scifi section
www.harrisonaudiolabs.com
Old 14th September 2012, 09:53 PM   #1163
Kindhornman's Avatar
Harrison,
Curious mind want to know. I do see ideas from Star Trek, so we all know that sometimes an idea is just before its time....
And that reminds me I have to complete a paper on advanced composites for a seminar speech I signed on to give.
Steven
Old 14th September 2012, 10:04 PM   #1164
gootee is offline gootee  United States
Originally Posted by OnAudio View Post
Fun stuff about parallel caps
How does each parallel cap see 8 Ohms when there is only a 4-Ohm load?? Impossible. If they are paralleled across 4 Ohms then they each see 4 Ohms.
But it SHOULD be about what the 4 Ohms sees. If the caps are the same as the original, it sees about twice the capacitance, about half as much inductance (ESL), and about half as much ESR. EVERYTHING is improved.
If the two parallel caps are each half the value of the original, then the capacitance stays about the same as the original but the ESL and ESR are probably less than half as much as with one cap, because the caps are smaller and can be placed closer and their connections and lead spacings could be shorter. HF behavior is improved.
Of course, for decoupling, the caps wouldn't usually be right across the load. They'd be from a power rail to the load ground, typically.
But if it was a trick question, then "out with it"!
Old 14th September 2012, 10:13 PM   #1165
Hehe, I knew that would tickle you. Using I = V/R. Assuming the load is 4 ohms and the voltage is 4 volts. A single cap would release 1A. Now if there are two caps, each cap would release 0.5A . R = V/I = 8 Ohms
Old 14th September 2012, 10:16 PM   #1166
All the best. Enjoy the space ship building
Originally Posted by Kindhornman View Post
Harrison,
Steven
Old 14th September 2012, 10:17 PM   #1167
gootee,
Is there some theoretical point where adding more capacitors becomes a problem? Do the multiple leads between capacitors end up adding some inductive or resistive problems at some point, or could you theoretically parallel hundreds of small value caps?
Steven
OnAudio,
Just trying to teach engineers how to build better aerospace and automotive parts faster and cheaper. Spaceships would be more fun. but my dylithium crystal are on back order.
Old 14th September 2012, 10:34 PM   #1168
Will send you my shipping address, needed some of that
Old 15th September 2012, 12:42 AM   #1169
Tony is offline Tony  Philippines
Tony's Avatar
gootee,
Walt Jung in his 1980 Audio magazine article "Build an Energy Storage Bank" mentioned this, he said at some point adding more capacitance, the lead inductance becomes significant to affect the results....i do hope he chimes in in this discussions...
Old 15th September 2012, 02:31 AM   #1170
danielwritesbac's Avatar
Sure fire recipe for very dull audio. With massive paralleling, there seems to be some treble killing gyrations going on. That's worse than a choke. It is about as bad as my SD669 capmulti. Oh fail! But I learned that any possible audio processor effects can be installed at the power circuit because whatever you do to the power circuit also affects the output. If on purpose, there's a powerful tool, but powerfully vexing if done by accident.
P.S.
A more customary spot to find the tone control feature is at the amp board's power cap sizes--bigger for more laid back (possibly duller) -or- smaller for more forward (possibly clearer). It isn't entirely a case of no free lunch. An even balance plus extra good noise filtering can get you a combination of both laid back and clearer but at the cost of more time investment.
P.P.S.
Your massively paralleled example is not problematic if the predrive is run on regulators. Well, that's the orthodox fix. I have a cheaper method, at post 1115.
Tools & GuidesClipNipper headroom boostParallel LM1875 pt2ptEasy parallel TDA7293 boardTDA7294 pt2pt ♦ My post has opinion.
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 04:12 PM
How do you calculate choke size in a power supply? Original Burnedfingers Tubes / Valves 25 5th January 2012 12:23 AM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 02:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 05:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 6th December 2007 11:50 PM
Copyright ©1999-2013 diyAudio
