Power Supply Resevoir Size - Page 113 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th September 2012, 02:56 AM   #1121
danielwritesbac's Avatar
Originally Posted by gootee View Post
The RC time constant is not a problem, when charging the decoupling caps on the amp board. You're thinking of the slower exponential decay of a larger capacitance's voltage, as it discharges current through a resistance. But look at the very beginning of that curve. There is no slow ramp UP to it. The current starts flowing blindingly quickly, and at its highest rate.
The power rails themselves do have resistance and self-inductance that could slow down the charging of the decoupling caps. But larger reservoir caps should only help make it faster and better for the decoupling caps, as far as I can see.
Nico's example is very frequently reported. The fix is easy (post#1115), but identifying the cause is totally a mystery to me. I wonder what situation keeps happening that slows down the reactiveness of the amp power bypass caps. So, would you say that the muddy blur of the overlarge example was from not responding fast enough for transients? Or would you say that the amp board power caps lost the competition for charge?
Question:
Did my schottky in post 1115 work by providing voltage drop, or did they work by preventing the charge from coming back out of the amp caps?
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 14th September 2012, 04:12 AM   #1122
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
HOWEVER, that job, the "fast" part of it at least, will be handled by the DECOUPLING CAPS, which HAVE to be very near the points of load (to be fast-enough), not by the reservoir caps.
and big enough to make it on their own
fortunately they are getting bigger these days
what is a transient anyway ?
many think of it as a small exstra signal
I would rather say its the full signal, plus some exstra
which is why I say the last cap should be big enough to make it on its own, basicly
Old 14th September 2012, 04:28 AM   #1123
Kindhornman's Avatar
A transient is that guy sleeping on the bus bench Just passing through, not staying around....
Old 14th September 2012, 04:31 AM   #1124
sounds lonely
and when he gets on the bus, not alone I guess
Old 14th September 2012, 04:33 AM   #1125
Yes, but with a sign he collects cash and doesn't pay any taxes.......
Old 14th September 2012, 04:37 AM   #1126
gootee is offline gootee  United States
A transient is everything except for steady state. Steady state is a sine wave "tone", or more than one of them, that have been playing for a long time and are not changing their amplitude or frequency.
Old 14th September 2012, 04:43 AM   #1127
I thought a transient would be a natural part of a peak ?
and most music I listen to mostly consist of constant peaks and transients
Old 14th September 2012, 04:47 AM   #1128
Yes Daniel it is preferable to clean the power before it gets to the transformer.
Old 14th September 2012, 04:49 AM   #1129
Seriously, "transient" is EVERYTHING that is not "steady state".
Old 14th September 2012, 04:53 AM   #1130
steady state doesnt sound like music to me
are you talking about test bench measurents ?
Valve power supply - How to size transformer? SanderW Power Supplies 25 4th January 2013 05:12 PM
How do you calculate choke size in a power supply? Burnedfingers Tubes / Valves 25 5th January 2012 01:23 AM
power supply bypass cap size BigE Power Supplies 11 5th July 2011 03:59 PM
Power Supply Case Size diymixer Power Supplies 1 10th October 2010 06:47 AM
What size power supply should I get for repair work? spooney Car Audio 3 7th December 2007 12:50 AM
Copyright 1999-2017 diyAudio
