DPS-600 fast regulated smps for Wire-Amp
Old 26th March 2013, 11:15 PM   #151
BuildMeSomething is offline BuildMeSomething  United Kingdom
Right, back home and stripped off the heatsink again and replaced the IRFP250 and 2 x 18NB40 Mosfets.
Still no joy. On Power Up, both green LED's light as normal for 1 sec, dim for 1 sec then starts a quick on-off cycle [roughly 2 pulses per second]?
Starting to feel like this build is jinxed
Paul
Listening with Gusto!
Old 26th March 2013, 11:44 PM   #152
NicMac is offline NicMac  Italy
NicMac's Avatar
Originally Posted by BuildMeSomething View Post
jinxed
meaning
Old 26th March 2013, 11:45 PM   #153
qusp is offline qusp  Australia
qusp's Avatar
cursed
Old 27th March 2013, 10:45 AM   #154
Yes, meaning cursed...
Nearly reached the point whereby I switch to Plan B.
Old 27th March 2013, 11:13 AM   #155
qusp's Avatar
have you spoken to Roberto about returning the unit to base for repair?
Old 27th March 2013, 11:32 AM   #156
No, not yet... Was hoping I could get it done here.
TBH, no real need for a 100W+ Power Amp, I made the wrong choice and should have gone for The Wire LPUHP.
Plan B is; The Wire PSU @ +/-25VDC > Input, & unregulated +/- 25VDC > output.
Old 27th March 2013, 05:09 PM   #157
qusp's Avatar
well to be fair, the LPUHP sold out in 24hrs...
you could bias this amp hard for full class A at 40-50W the DPS600 will handle that, just start up with low bias 50-100ma or so and then crank it up to 800ma-1A
Old 27th March 2013, 11:08 PM   #158
Yep, I saw the LPUHP thread not long after it was first posted, however at the time was of the mind set that more power was required...
Am still considering switching to a higher bias after start-up, it's just making the switch fool proof enough. Plus integrating some thermal protection for the higher temps.
Could possibly utilise a Raspberry Pi running a basic start-up program, allowing switching to/from standby and set Low/High bias via momentary switches or from a GUI.
It was me not correcting the bias while testing, that blew this unit in the first place. Fingers crossed that it can be made to work again
Old 28th March 2013, 02:17 AM   #159
hochopeper is offline hochopeper  Australia
Thanks for the heads up about making sure I check the bias before starting while I test it, I'm getting closer to testing mine in the next few weeks. Ideas cooking for bias switching So, don't focus too much on solving that problem for now.
I'm with qusp sending the DPS600 back to Roberto for repair is looking like an good option at the moment.
Old 19th November 2013, 08:55 AM   #160
Stammheim is offline Stammheim  Germany
Hi guys,
as the DPS600 is noticed anywhere, where "The Wire" can be found, I asked myself, where it could be bought, as AudioPower only has the 400-/ 500-series. Is it still not in a final status?
Another information I couldn't find is the AUX-voltage, which should be higher for my (LME-) usage than the output voltage..
Many thanks,
Stammheim
DPS-600 fast regulated smps for Wire-AmpHide this!Advertise here!
Simple regulated SMPS for my Ghettoblaster (pics) Lope Power Supplies 1 9th June 2011 11:20 PM
Fast capacitors for SMPS Joshua_G Power Supplies 6 14th July 2010 08:06 PM
fast versus schottky diodes for smps jamesrnz Power Supplies 8 3rd September 2008 11:42 PM
Regulated or non-regulated SMPS longitude Class D 5 8th May 2007 03:02 PM
SMPS regulated output MaXiZ Power Supplies 1 24th December 2005 08:10 AM
