DPS-600 fast regulated smps for Wire-Amp - Page 11 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th November 2012, 04:17 PM   #101
Workhorse's Avatar
AP2,
Can we connect the load from + to - rail, excluding GND ?
Old 5th November 2012, 06:26 PM   #102
qusp is offline qusp  Australia
qusp's Avatar
this again? just read back a few pages and you'll have your answer
Old 5th November 2012, 06:46 PM   #103
AP2 is offline AP2  Italy
Banned
Originally Posted by Workhorse View Post
AP2,
I already explain this. (if you want use with amplifier) this smps want load on one side at time, even switched very fast. reason that is not good for two amp's,independant of total power.
for test yes, i have tested 10R to -vcc to +vcc at +/-62V. even for 10sec. i not see any problem.
Old 5th November 2012, 11:04 PM   #104
Default Wired
Those pics of how it was wired...
Not included the speaker [Mission 78cse 8Ohm] or mains leads.
Ran the setup friday night & saturday night for roughly 2hrs total with the resistors in place. Sunday; removed the resistors and it started fine without the O2/cd player connected. On for roughly 10 seconds before it was turned off. Connected the O2/cd player and turned on source - O2 - dps-600. unit started up then after roughly 6 seconds shut down with both led's blinking.
Listening with Gusto!
Old 6th November 2012, 09:29 AM   #105
Banned
Good table..eheh.
Some advice independant of all:
HeatSink is better connect to base panel of dps-600.
Connect heart of dps-600 (see my old pic for this) it is necessary,specially in this your connections.
Bias measurements:
in the measurement of bias, considered that the flow is transverse (not affected the load (speaker).
At 400mA,with your voltage setup, wire-amp dissipate 38-40w (only Mosfet) ..simple info.
Old 6th November 2012, 10:36 AM   #106
Thanks, I'll implement those changes before doing enything else, plus add the standby switch. I will back off the bias and adjust anew...
Originally Posted by AP2 View Post
ah .. well! This is a special extra protection in the event fails the power regulator, just not to damage the amp, or other devices associated with the DPS-600.
I honestly do not understand how it can happen.
If you are able to replace the one mosfet smps, I can send, or you buy it, and I will refund.
looks like you have some damaging loop. in this case it is preferable that lowers the bias current, just to investigate the noise.
Am I looking to replace Q2, Q3, Q5... or something else?
have replaced the res-fuse on the first smps?
Not yet, the diode under the LM317 appears to be no good also, I'll replace it & the reg to be on the safe side.
Old 6th November 2012, 10:49 AM   #107
Banned
Only Q2 need to change. (In reality, the dps-600 works for 1 sec., the supervisor break because the output voltage is higher than 20%)
For diode i not think, it is 3Amp also. 1R-Fuse save all in this area.
i send pm today later for disassemble Q2.
Old 6th November 2012, 11:14 AM   #108
Right just Q2 [1 X IRFP250], had a quick look does it need to be 200V 33A or possible to use 200V 30A?
Thanks again, I WILL get it all working & trouble free
Old 6th November 2012, 12:37 PM   #109
Workhorse's Avatar
What if 2 half bridge amplifier modules are connected to this smps and configured in bridge configuration, in that case the LOAD CURRENT will pass thru + to - rail without going into GND. Will it have same regulation or something different is expected?
This was the reason for asking again.
Old 6th November 2012, 01:05 PM   #110
qusp's Avatar
umm do you think we could keep this to discussion of this supply with THIS amplifier as mentioned in the subject? how praytell is this productive?
Simple regulated SMPS for my Ghettoblaster (pics) Lope Power Supplies 1 9th June 2011 11:20 PM
Fast capacitors for SMPS Joshua_G Power Supplies 6 14th July 2010 08:06 PM
fast versus schottky diodes for smps jamesrnz Power Supplies 8 3rd September 2008 11:42 PM
Regulated or non-regulated SMPS longitude Class D 5 8th May 2007 03:02 PM
SMPS regulated output MaXiZ Power Supplies 1 24th December 2005 08:10 AM
Copyright 1999-2017 diyAudio
