Do batteries still rule? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th July 2012, 04:56 AM   #1
Default Do batteries still rule?
Hi, I powered my light dependant resistor pre-amp (LDR lightspeed) off a 12V battery (deep cycle lead acid) and found that it sounded better (more seperation of instruments, voices, etc).
Prior to this, I was using either a ALW super reg or the Teddyreg. So I'm thinking of making the battery supply permanent, which of pcurse leads to two questions:
1. Is it still the case that batteries exceed the performance of discrete regulators?
2. What would be the best recharging circuit for the lead acid battery?
Ryan
Old 10th July 2012, 06:14 AM   #2
analog_sa's Avatar
Not sure why you compare batteries to regulators. After all the complete mains PS involves transformers and rectifiers and these need to be optimised before serious comparisons are done. Clearly regulators don't do much, if anything for the RF in the mains.
Not many diy projects also involve some of the more advanced rectification solutions, like synchronous or mains-isolated rectification. Surely there is room for improvement there.
So, yes, batteries still offer an easy solution. Probably not lead acid since Lifepo4 batteries are widely available.
Old 10th July 2012, 07:19 AM   #3
Thx analog_sa. So, any suggestions on mains-isolated rectification?
Old 11th July 2012, 11:30 AM   #4
analog_sa's Avatar
Been thinking of building something alone these lines
http://www.eie.polyu.edu.hk/~cktse/p...er/PE-9505.pdf
but probably using a micro
Too many projects atm
The Golden Rule? jered22 Full Range 22 12th June 2013 11:27 PM
One PSU to rule them all! frasco Power Supplies 7 26th January 2013 01:41 AM
What I got for breaking my own rule.... JoeDJ Everything Else 4 19th July 2011 10:25 PM
Golden Rule???? Higo Multi-Way 5 14th March 2002 12:57 AM
Copyright 1999-2017 diyAudio
