Regulated Capacitance Multiplier Supply Board - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th July 2012, 11:47 AM   #1
Default Regulated Capacitance Multiplier Supply Board
I have been using this supply for a few months now and it seems to work very well.
It is meant to be used with Class A Headphone amplifiers.
Simple LM317/LM337 preregulation and then 2 x 750 HFE 4A Darlington transistors in the cap multipliers.
Output will be around 2-2.5 volts less than what the LM317/LM337 preregulators output is set at, depending on current draw.
Not exactly advanced but it seems to get the job done.
EDIT : Shown is my second version, with a few more ground connections as well as a few other changes, otherwise it is the same as the one I have been using.
Old 10th July 2012, 08:19 AM   #2
kp93300 is offline kp93300  Malaysia
hi
Does it matter which darlington to use in the cap multiplier?
thks
kp93300
Old 10th July 2012, 12:42 PM   #3
marce is offline marce  United Kingdom
Nice arial design.
Old 10th July 2012, 01:40 PM   #4
Elvee is online now Elvee  Belgium
Elvee's Avatar
Swapping the order of the regulators and cap multipliers will improve the low/medium frequency output impedance, and leave the ripple rejection unchanged.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 11th July 2012, 03:14 PM   #5
I built this for supplying pure Class A headphone amplifiers so a high and/or varying output impedance is not something I'm too worried about.
The way I have done it with the regulators first and the cap multipliers last helps reduce the noise from the regulators. With the cap multipliers before the regulators you would not get the same attenuation of regulator noise.
Sure it makes the supply more or less unusable for anything else than Class A but since Class A is what I like to design with for headphone duty it is a non issue.
But I see your point.
Old 12th July 2012, 06:47 AM   #6
Elvee's Avatar
It does make sense in that particular context.
Old 12th July 2012, 09:11 AM   #7
jan.didden's Avatar
... which makes sense assuming that the reg noise is larger than the cap multiplier noise. Is it?
BTW nice PCB design.
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 12th July 2012, 12:23 PM   #8
Why not just use a ground plane
Old 12th July 2012, 04:17 PM   #9
jan didden
I'm just assuminmg that the cap multiplier nosie is less than the regulator noise.
I could be wrong(But I hope I'm not).
Old 12th July 2012, 04:21 PM   #10
With a groundplane you do not have as much control of where the currents flow in your ground as with a star ground arrangement.
With a star like arrangement like what I have used I can keep the nasty half-wave rectified current pulses from the rectifiers and the first caps before the regulators away from the regulator and cap multiplier ground. The rectifier and first cap currents are resolved locally and do not contaminate the other grounds.
You could do it even better with a separate ground for rectifiers and first caps, a second ground for the regulators and then a third ground for the cap multipliers.
Rod Elliott's capacitance multiplier supply 454Casull Power Supplies 21 24th March 2010 01:40 PM
Problem with capacitance multiplier power supply jscherer Parts 15 22nd March 2009 02:08 PM
Capacitance Multiplier Power Supply Redshift187 Chip Amps 5 15th January 2009 12:34 PM
33000 uF capacitance on input of LM338 regulated supply for LM3886 bikehorn Chip Amps 3 7th July 2007 09:47 AM
Cap. multiplier or regulated supply ? Buhl Pass Labs 1 8th October 2003 10:51 PM
Copyright ©1999-2017 diyAudio
