diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   What SMPS topology is this? (http://www.diyaudio.com/forums/power-supplies/215623-smps-topology.html)
db! 4th July 2012 05:05 PM
12AX7 Tube (valve) Preamplifier Kit
I'm looking to build a similar SMPS for another project but I'm having some trouble identifying what identifying what topology it uses. It's not quite a flyback converter nor is it a forward converter either.
Any help would be appreciated!
Elvee 4th July 2012 05:12 PM
It is an ordinary flyback converter, based on an auto-transformer inductor.
megajocke 5th July 2012 04:23 PM
I've seen it referred to as the "Tapped-Inductor Boost Converter". It allows a higher output/input voltage ratio than the traditional boost converter. You could also view it as a flyback converter with its output stacked on top of the input voltage that uses an autotransformer.
See for example
http://rap.rgcanseco.net/files/Docum...0Converter.pdf
db! 6th July 2012 02:43 AM
Thanks for the help guys!
Resources saved on this page: MySQL 18.75%
