Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th June 2012, 11:30 AM   #1
Default Power supply simulating problem
I am designing 300W power supply with 300V output. my design based on tl494 . I used it in Boost topology . I want to have 300V output . so I calculated the parameters . but when I simulated it in LTspice . the output voltage was aboat 190V !!! I changed many parameters but the output did't changed anymore. SO I don't now what to do!!! plz check my circuit and tell my what is wronge with it .
Old 29th June 2012, 11:53 AM   #2
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
What circuit?
Old 30th June 2012, 07:11 AM   #3
Sorry!!!!
Old 4th July 2012, 03:27 AM   #4
gootee is offline gootee  United States
You might want to include the symbol files and models for the ICs. Before re-uploading a zip file, try putting it into a new folder, unzip it, run LTSpice, and make sure that everything that's needed has been included, i.e. it displays and runs OK.
It would also be a good idea to grab the LTSpice schematic screen image to the clipboard (Tools-->Copy Bitmap to Clipboard) and then paste it into Paint and then save it as a jpg or png and then post it here. Not everyone has LTSpice.
LTspice - problem simulating simple rectifier Pinkevin Power Supplies 14 19th August 2010 10:08 AM
power supply problem chopchip Tubes / Valves 96 24th July 2010 01:03 PM
Power supply problem vidc Power Supplies 9 26th May 2010 05:29 PM
Power supply problem Niila Tubes / Valves 6 12th April 2008 01:39 AM
Power supply problem (or something) ir Chip Amps 4 23rd August 2003 08:44 AM
Copyright ©1999-2013 diyAudio
