What's wrong with this circuit?
Old 30th June 2012, 03:39 AM   #11
Redshift187 is offline Redshift187  Canada
That's great news. It overheated slowly enough that that could be it. I'll swap the resistor out tomorrow and see what happens.
Edit: I see how it happened. I put about 12V in the calculator I saw, but my wall-wart is 12V AC, which gives a lot more DC. Oops.
Tyler
Old 30th June 2012, 12:59 PM   #12
noSmoking is online now noSmoking  United States
noSmoking's Avatar
you need DC not AC if you use AC you need a full wave bridge for + - dc.
Old 30th June 2012, 01:12 PM   #13
noSmoking's Avatar
hi,
If you combine these you might have what your after
Change polarities for negative side ,Are you going to use 2 circuits cause you won't get + and - 10 vdc out of a single 12 ac
Did you get the Stabdesign.exe Calculator to work ?
You will need more voltage to get + and - 10 volts out or build 2 circuits,google got a bunch of drawings,for full wave dual power supplies.
Good luck!
Old 30th June 2012, 01:26 PM   #14
noSmoking's Avatar
here one I found for you
Old 30th June 2012, 02:21 PM   #15
Oh no, I understand I need D.C. I've got a voltage doubler before the regulators to give me +/- DC from a single AC wall wart :-)
Tyler
Old 30th June 2012, 02:25 PM   #16
Aka a Delon bridge.
Tyler
Old 30th June 2012, 05:12 PM   #17
noSmoking's Avatar
Well then I hope you got enough info to do IT!
Good luck,
NS
Old 30th June 2012, 05:16 PM   #18
Thanks so very much for the help! StabDesign is great!
Tyler
Old 30th June 2012, 08:39 PM   #19
noSmoking's Avatar
your welcome that's why this site is great,People here have help me alot !!!!!!
Stabdesign is a keeper,If you need others Caps,ect. google it ,I use them often!
Old 6th July 2012, 07:56 PM   #20
How do I calculate the power dissipation?
Vin * Iout
Vout * Iout
(Vin - Vout) * Iout
Tyler
What's wrong with this circuit?Hide this!Advertise here!
Whats wrong with this circuit? Hamstein Tubes / Valves 13 14th May 2012 10:58 PM
With painted a circuit, STI(2SK182E) pipe of the SRPP circuit, is feasible? lgqliu Solid State 2 25th February 2012 06:07 PM
I Was Wrong Borat Planars & Exotics 3 18th November 2009 08:36 AM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
