LM317 safe operating temperature
Old 28th June 2012, 09:35 AM   #11
mkusan is online now mkusan  Croatia
Originally Posted by wintermute View Post
I guess the other question that should be asked is safe for the device or safe for it's surroundings cooler means less stress on nearby components and also less likelyhood of developing dry joints.
Long legs, and a decent distance from other components should allow a higher operating temp, than mounted close to the board and close to other components.
Tony.
Hi Tony,
the board is rather empty around this regulator, except for one film cap.
I thought about extending the legs of the regulator but was not sure about its caveats, higher resistance comes to mind. And I do not have enough knowledge to determine whether extra couple of cm would have any significant impact on the regulation.
Marko
Old 28th June 2012, 09:39 AM   #12
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
There is no need to worry about bad influence on the sorrounding components if the working temperature can be stabilised below 50 or 60 degrees, even more so if as what you say the board around it is sort of empty.
Old 28th June 2012, 09:43 AM   #13
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
The datasheet recommends connecting direct to the case of the regulator for resistance reasons. See this except from the national datasheet.
So yes lead length could make a difference depending on the implementation details
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 29th June 2012, 06:25 AM   #14
New, bigger heat sink managed to shave-off temperature considerably.
Even the lid now seems cooler to touch.
Thanks everyone for kind advices
Marko
Old 29th June 2012, 06:46 AM   #15
MarianB's Avatar
Congrats on the succes
As i see you could even try fitting a small cooler inside, to ventilate the device and that way you will have no more worryes about the temperature, but the worm air has to be able to escape the case.
Old 29th June 2012, 07:40 AM   #16
Hi MarianB,
I am afraid that the small vent would be noisy, and the silent one would be expensive. I could be wrong but I have a feeling that this setup is even more cool than with the old LM7805 in place, at least judging by the lid temperature (finger testing not exact numbers here).
What I am contemplating now is a separate regulator for either SAA7220 or TDA1543. Any thoughts on that?
Marko
Old 29th June 2012, 07:51 AM   #17
MarianB's Avatar
Well my small cooler sugestion was just that, a sugestion, as i see you could do just fine without it.
As i understand, both SAA7220 and TDA1543 requires 5V and a small current so maybe a 7805? it could even do without any heatsink if supply voltage for it is at about 9V.
Old 29th June 2012, 08:02 AM   #18
You are absolutely correct, all these chips were powered from just one LM7805 which I now substituted with LM317. My plan was to use same inbuilt transformer which gives as already stated 9.47V and I now have one LM7805 spare. Only question is it worthwhile doing this?
Marko
Old 29th June 2012, 08:06 AM   #19
MarianB's Avatar
Tell me please, why did you susbtitute the 7805 with 317 if it wasn't foulty?
Old 29th June 2012, 08:18 AM   #20
No problem
Reason 1. I have to solder something, I acquired a bug on this forum which even my wife cannot cure
Reason 2. This links made me think that LM317 is superior to Lm7805
Using 3-pin regulators off-piste: part 1
Ray's Audio Page
LM317 safe operating temperatureHide this!Advertise here!
Max safe operating temperature for transistors inside modified factory amplifier azzajonesy Solid State 8 8th October 2008 12:00 PM
Safe operating temperature. ronjodu Chip Amps 7 31st May 2007 12:11 AM
safe operating area TroelsM Solid State 39 23rd January 2005 08:19 PM
