DIY KIT Power supply for Squeezebox duet and Touch - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th June 2012, 11:05 AM   #1
Default DIY KIT Power supply for Squeezebox duet and Touch
Hi everyone,
i'm looking at a DIY kit power supply for my actual squeezebox Duet and potential next squeezebox Touch.
I'm located in France, and do not find any reseller selling this kit to build.
only fully assembled and expensives PSU are available.
Can you tell me either:
a website selling this kit to build from scratch
a BOM list to buy on Mouser or on Audiophonics or somewhere else for building it from scartch
Thank you very much in advance
Old 27th June 2012, 11:32 AM   #2
You can take a look here. The article is in dutch, but if you use google translate, you will see this will probably meet your needs
De betere zelfbouw voeding voor de Squeezebox
Old 28th June 2012, 10:55 AM   #3
Hello tubesforlive,
i viewed the post, thanks
Even quite difficult to understand with google translate.
but anyway it's a first step in this PSU build
thank you
If anyone has other idea/links, i would be please
thank you in advance
or maybe also if we create a GroupBuy
Old 29th June 2012, 08:31 PM   #4
If you need some translating for specific parts, just let me know. I can translate parts to english if you want.
Old 29th June 2012, 11:01 PM   #5
hangguy is offline hangguy  United States
I have been using the Salas SSR1.1 to power my Squeezebox Touch and it works and sounds great.
http://www.diyaudio.com/forums/group...shunt-reg.html
Teabag runs group buys on boards and kits regularly.
Mike
Old 10th July 2012, 03:30 PM   #6
Hi hangguy,
i'm discussing with Teabag right now, he wanted me to double check the power needed for the SQB Touch, i tell him that the Touch would need 5V 5A and the Duet would need 9V 3.5A are you in phase with that or not
Old 10th July 2012, 05:35 PM   #7
Originally Posted by jayce996 View Post
Hi hangguy,
I setup my Salas Shunt for 5V1A on my Touch and it is running just fine. If you don't connect USB drive to the Touch, I believe the Touch only draws 800mA or so. If you connect a USB drive, it may draw as much as 1.5A.
I don't have a Duet so I cannot comment on the current draw.
Old 13th July 2012, 02:13 AM   #8
Hi everyone,
I also had this squeezebox Touch and going to build a good PSU for him.
However, my understanding is that it don't need such high 5V 5A(@25W). I think normal 5V/2A should be enough to drive this unit.
I will build my own PSU using LT3080 + by pass PNP transistor to expand output current.
Roy
Squeezebox Touch -- Modifications soundcheck PC Based 971 7th December 2016 04:56 PM
NAS - SqueezeBox Duet OR PC dgtn2010 PC Based 53 25th August 2014 06:40 PM
Squeezebox Duet Clicks and Pops Dust PC Based 3 19th February 2012 08:40 AM
New power supply for Logitech Duet VT67 Power Supplies 6 30th May 2010 03:41 PM
look at low power amp for 4x SqueezeBox Duet psykosonik Class D 2 2nd October 2009 06:42 PM
Copyright 1999-2017 diyAudio
