Snubber caps with sic rectifiers?
Old 25th June 2012, 10:10 AM   #1
john dozier is offline john dozier  United States
john dozier's Avatar
Default Snubber caps with sic rectifiers?
I am changing out some normal rectifier diodes to Cree SIC rectifiers. There are currently snubber caps in place. Do I leave these or remove them? Thanks
Evil looms. Cowboy up. Kill it. Get Paid.
Old 25th June 2012, 10:31 AM   #2
R.I.P.
if they are capacitors alone with no series resistor then remove them.
If they are a proper snubber with a resistor then leave them in place and try the circuit to see if the existing snubber is doing a good job or even not needed.
The snubber part that damps the oscillation is the resistor. The capacitor simply moves the frequency of the oscillation.
regards Andrew T.
Snubber caps with sic rectifiers?Hide this!Advertise here!
Hexfred or SIC rectifiers in choke supplies john dozier Tubes / Valves 10 22nd January 2012 12:43 AM
Snubber caps atmars Tubes / Valves 2 15th November 2008 01:10 PM
adding caps and snubber network to LM3875 power board quickshift Power Supplies 0 19th August 2005 02:12 PM
SiC Schottky rectifiers. TugaTweaker Tubes / Valves 14 29th June 2005 07:57 AM
FYI: SiC Schottky bridge rectifiers JohnG Solid State 1 27th July 2002 05:40 AM
