hey guys been pulling my hair out trying to find a power supply schematics for a +45v and -45v power supply. its the only thing holding me up in my build and im not going to lie i need help as everything i try just doesn't seem to give me the negative voltage i need.
any help with be much appreciated. thanks sam this is the amp im building if its any help. 300 Watt MOSFET Real HI-FI Power Amplifier | EEWeb |
#2 |
just another
Hi Sam I've moved your thread to the powersupplies forum. You might want to have a read through this Elliott Sound Products - Linear Power Supply Design It's pretty long but should give you a good grounding in powersupply design
Tony. |
#3 |
hello thanks, sorry still learning where things go
on a seccondry note, how do i workout what the primary and seccondry inductance will be on a 300va 45-45v transformer?
#4 | |
Project 101 - High Power, High Fidelity MOSFET power amplifier
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#5 |
because im using a software called proteus (what i was trained on) and need to know how to set up a transformer
#6 | |
In the mean time, utilize extreme care with the supply, and I'd definitely do some reading on the suggested Elliot Sound site. That site is a wealth of audio and power information that seems to be very accurate and science/measurement-based. On a side note, you may want to search this site for information on the amp you built/are building. A cursory look shows an issue with the bias circuit and a couple other potential problems. With the vast history of amp reviews done on this forum, your amp is bound to have been looked into, so you shouldn't need to start a new thread.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
#7 |
A simple Dual rail linear PSU for a power amp isn"t really that tough ......
A 2 x 35v AC transformer or a 70v CT transformer with a 25A bridge rectifier , 4 x 10,000uF 50V+ caps , a couple 1w resistors and a couple small film caps for the snubber will get you a quiet reliable PSU for a power amp ...... I have never had to simulate this type of PSU as most are very simular , some with more capacitance and some with less ...... the designer of this amp says he prefers to use a lower capacitance PSU which i don"t agree with at all but to each his own ..... Cheers |
#8 |
here is my current design, it uses a 300va 45-0-45 transformer (currently being substituted with two alternators running at 45v each) bridge 1 is a 200v/35a and the +/- 45v is working perfectly. its the +25v im having trouble getting to work, its very unstable, anyone got any ideas? thanks sam
http://i1094.photobucket.com/albums/...rridge/pic.jpg |
#9 |
Bump
#10 |
Your schematic is very small and hard to read. What voltage is coming across C6? It looks like you are missing a voltage-dropping resistor on your 25v+.
| Power supply protection circuit against main supply ? | guitar89 | Power Supplies | 22 | 28th February 2012 03:25 AM |
| Power supply positive-negative-ground from a single power supply | mome | Power Supplies | 8 | 9th September 2011 05:17 PM |
| Hagerman Bugle power-supply or for +/-15dc 100ma generic supply. | tweakk | Swap Meet | 3 | 23rd February 2011 06:46 PM |
| DIY Audio Alchemy Power Station 2 Power supply PSU with case | roscoeiii | Swap Meet | 2 | 29th May 2010 06:51 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
