Need help:Power supply Capacitor!
Old 19th June 2012, 12:20 AM   #1
Itsme is offline Itsme  United States
Exclamation Need help:Power supply Capacitor!
I'm trying to repair a transformer that blew a capacitor inside of it and I can't make out what to replace it with. All I can make out on it is a "63" and "12" it looked like a film capacitor with heat shrink on the outside. I found the numbers on the heat shrink part so not sure if anything to do with capacitor? If somebody could give me a good guess of what to replace it with I would be great-full! Here are some pics of the power supply.
T-opto transformer 007.jpg.
Old 19th June 2012, 11:25 AM   #2
DF96 is offline DF96  England
You have given us four good pictures of the burnt PCB, and two out-of-focus pictures of the capacitor. The other way round would be more helpful!
Although the box describes itself as a transformer, it appears to be an SMPS.
Old 19th June 2012, 04:53 PM   #3
Sorry, Capacitor was so damaged i didn't think it would be much value to look at. The two numbers I found were on the small crumbs that broke off of it.
Any other pictures needed please let me know.
Old 19th June 2012, 04:55 PM   #4
forgot pics.
Old 19th June 2012, 05:00 PM   #5
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Replace the power supply. Less costly than attempting to repair it.
Frank
Old 19th June 2012, 06:29 PM   #6
RJM1 is offline RJM1  United States
just a guess: ECQ-V1J124JM3 Panasonic Electronic Components | Mouser
Old 19th June 2012, 08:27 PM   #7
barrymagrec is offline barrymagrec
This looks like an "electronic transformer" for low voltage lighting, ie, as mentioned above, a switchmode PSU. It is very unlikely that simply replacing the blown cap will effect a repair. If you are not experienced with this type of PSU it is not advisable to try and repair it.
Old 19th June 2012, 10:17 PM   #8
Originally Posted by Itsme
forgot pics.
OK, I see what you mean! You would need to discover what made this cap go up in flames. Probably best to just replace the whole unit, unless you are skilled in fault-tracing on SMPS.
Old 19th June 2012, 11:17 PM   #9
Yes, I am pretty good with fault tracing. I work on mainly audio equipment and video equipment. But I was hoping to maybe come across someone familiar with this type of electronic transformer that would make me feel better about my guess of what would replace it.
The problem was, they had 300 watts of light load on a 250 watt electronic transformer. This is the last capacitor in the circuit before going into the flyback to convert down to 12 Volts so it carried most of the load in high voltage. all the high voltage npn's check out good.
I guess worse case scenario I will send off an email to the manufacturer and ask what goes in the c8 slot.
And to the other guys suggesting replacement - I like to be challenged
Old 19th June 2012, 11:30 PM   #10
Originally Posted by RJM1 View Post
thanks RJM1, But I'm thinking it needs to be in the 700-1,000 volt range, the small ceramic caps are 1kv around it and another metalized film in c2 position is 630 volts. My guess is Metalized Film 1kv 1.0uf? just not sure.
Need help:Power supply Capacitor!Hide this!Advertise here!
LM4780 Power Supply Capacitor Einric Power Supplies 6 26th May 2011 01:31 PM
Power supply capacitor replacement dognut Solid State 4 11th March 2010 02:24 AM
Power supply capacitor grenaded valterdaw Car Audio 6 18th July 2006 04:44 PM
Sunfire Power Supply Capacitor ainami Solid State 19 12th September 2004 01:43 PM
Capacitor across A/C inputs in power supply? Cloth Ears Solid State 8 4th June 2004 01:36 PM
Copyright ©1999-2017 diyAudio
