how to simulate schematic
Old 8th June 2012, 07:45 AM   #1
samoloko is offline samoloko  Bulgaria
Default how to simulate schematic
Hi
I have found interesting discrete voltage regulators Discrete Voltage Regulator - John Swenson - Computer Audio Asylum and would like to view how they are simulated
I have draw schematic but don't know what to do to get simulated results like noise vs freq and output impedance vs freq
Old 8th June 2012, 08:04 AM   #2
Oliphant is offline Oliphant  New Zealand
Draw this circuit in any spice simulator. There are many free ones available such as Tina-TI or LTspice. Circuitmaker 2000 is also very good for this sort of thing.
Old 8th June 2012, 08:15 AM   #3
It Is drawn In LTSpice but when I run simulation I got error logs
have you seen attachment
Old 8th June 2012, 08:53 AM   #4
Elvee is offline Elvee  Belgium
Elvee's Avatar
Why do you zip your files? It is a PIA, and with the new forum capabilities, you have no excuse to stick to it.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 8th June 2012, 08:55 AM   #5
jcx is offline jcx  United States
I1 is at least 10x too high
do a .TRAN type analysis for debugging a Spice sim - save the .NOISE for after the .TRAN shows proper cirucit operation
you can cruise the schematic following a successful .TRAN with the cursor and the DC operating point I, V will be displayed in the lower left corner as the cursor moves over wires, device terminals
Old 8th June 2012, 09:48 AM   #6
I have corrected I1 to 0,005A and also output cap to 100uF and program run simulating output voltage at 5V but I would like to know what settings to set to get noise of regulator and output impedance
Old 8th June 2012, 10:54 AM   #7
euro21 is offline euro21  Hungary
Proper Noise syntact:
.noise V(out) V1 oct 5 2 25000
Old 8th June 2012, 01:11 PM   #8
thank you euro21
would you please tell me how can I view output impedance vs freq
regards
Old 8th June 2012, 06:53 PM   #9
Add signal generator to output. Signal AC=1V.
Run 'AC Analysis'. 1Hz-1MHz, 10 point/octave.
Click on 'out' node.
Edit 'AC Analysis' window title -right mouse click on title- (now V(out) ) to V(out)/I(V2).
Change 'AC Analysis' window left (vertical) menu (now decibel) -left mouse click- to 'Linear'. Thereafter it is Ohm.
Old 8th June 2012, 08:10 PM   #10
a Current Source is more commonly used for testing Voltage Output node impedance - like the Output of Voltage Regulator circuit
and the I1 bais current is still totally unrealisitic - the LED would be a DED at 1/4 A
the .Noise and .AC analysis can be misleading - they only operate on the small signal linearized model derived from the DC operating point analysis on start up
they don't show any nonlinear, saturation, reverse bias conditions that your test signals could cause in a "real sim"
really the only "safe" way to use the .AC based sims is after you have tested with .TRAN, simmed with realistic load, test sources with sine, or pulse/ramp waveforms
how to simulate schematicHide this!Advertise here!
Anybody willing to simulate ? east electronics Solid State 28 24th January 2012 11:51 AM
Need some help to simulate Aleph 5 guitvinny Pass Labs 7 1st January 2008 04:11 PM
Someone willing to simulate a TL for me? tubee Multi-Way 21 27th November 2007 03:25 PM
Paid to simulate steve_mak Solid State 3 8th July 2007 06:34 AM
Can anyone simulate these Vifa's for me please. K-amps Multi-Way 9 31st May 2005 04:17 PM
Copyright ©1999-2017 diyAudio
