Why no FWB output for SMPS - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th June 2012, 02:38 AM   #1
Default Why no FWB output for SMPS
Does anyone know why a FWB with no center tap is rarely used for a single output with a half or full bridge SMPS. In fact it is not very easy to even buy a ultra fast FWB for SMPS use.
Old 8th June 2012, 04:47 PM   #2
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Cost/efficiency, I'd imagine.
You're buying twice as many diodes, and 2x the diode drop = 2x the power loss in the output rectifier which means you're buying 2x the heatsinking etc.
Full bridge rectifier output saves a winding in the output transformer, but the full bridge winding has to handle more average current requiring thicker wire or more strands, meaning no copper savings.
Old 8th June 2012, 05:21 PM   #3
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
From my (large) experience repairing SMPSīs of various types, also add that it is relatively rare to have a fault in a transformer, while it is normal to find a shorted diode, so reliability is also reduced when more silicon is added.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 8th June 2012, 05:25 PM   #4
wrenchone's Avatar
Adding the extra drop only makes sense at higher output voltages, where you can reap the advantages of a simpler output winding. It also reduces stress on the output diodes - important at higher output voltages. At the usual 5/12/24V levels, it doesn't make a lot of sense.
Old 10th June 2012, 02:02 AM   #5
I found this out from the book Transformer and Inductor Design 3rd edition by COLONEL WM. T. MCLYMAN. Chapter 7 -4
The total apparent power into the SMPS is the following.
2x the load power for a FWB to FWB converter.
2.414x the load power for FWB to a FWB CT.
2.828X the load power for a CT input and FWB CT output.
Also from Wikipedia, power factor is the ratio of real power to apparent power.
My conclusion is, without power factor correction a FWB output can have lower primary current. However if you use power factor correction, i am not certain how good the above multipliers can be improved.
What happens with an output choke on a SMPS rickmcinnis Power Supplies 1 10th September 2010 05:30 PM
Quick question about CT and FWB athos56 Tubes / Valves 5 2nd May 2009 04:27 AM
Variable output SMPS Razor-Edge Power Supplies 7 3rd August 2007 11:37 PM
SMPS regulated output MaXiZ Power Supplies 1 24th December 2005 08:10 AM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright Đ1999-2017 diyAudio
