I super need 12V to +-85V 20A POWER SCH
#2 |
I would say push pull, just big enough to do what you need... btw, you are talking about several kw of power, that might need 4-8 transformers, 2 fets min. per trafo, 2-4 diodes per trafo
I mean, this will cost you a good deal of money just to have parts, a lot of it in copper wire |
#3 |
With 100% efficiency you would need to draw 283 amps from your 12V supply. You would need a 000 or larger gauge wires to connect to your 12V source.
American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies Last edited by RJM1; 6th June 2012 at 07:24 AM. |
#4 | |
#5 |
Attached is a schematic for a SMPS with ratings close to what you're looking for. It was for an 800WRMS car amplifier. It's a 1.5KW switching supply switching 12V up to +/- 68VDC. It could pull 150A continuously, but was mostly designed for intermittent duty associated with audio signals.
All this power was switched through a single 3C81 Ferroxcube toroid core. Of course, this was an older supply using bipolar's as switch devices. I built a similar supply delivering 1.4KW, but I used MTP50N05 FETs forgoing the driver transformer. For your needs, you would probably need two identical, comparable power supplies with each rated for 12V @ 150A switching to 80VDC @ 20A. Then connect the two supply outputs in series to get your desired +/- voltages. It would be a monster of a supply, but can definitely be done.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
#6 |
very thank thank thank thank
#7 |
hello dear friend
my name is Hadi from iran i want to creat my own car amplifier but can not to creat smps for that. i see in diy site you do that in past. can you please help me to creat a good smps? sory for my bad english my email adress is Hadi_ghr_e_61@hotmail.com very thanks for your helping. have a nise day dear friend. |
#8 |
u can use this circuit,but you have to modify this circuit
#9 |
Might I suggest a simpler approach to all this.
Get yourselves some 12volt solar inverters designed for 50 cycles operation and use those. A company in Queensland Australia called Latronics Sunpower makes 7Kw inverter using a PIC driving some 24 Mosfets on a small ( for 7KW ) heatsink. Because the Mos-Gate FETS run so efficiently (about 98%), due to the low Source-Drain on resistance, they don't need a massive heatsink for continuous use - unlike bipolar devices. The output transformer is a standard 24volt centre tapped - 240 volt toroid ( power transformer ); rated at 7KW. You would need to rewind the toroid to the voltage you need. Your second choice is adapt a UPS from an old computer. Rip out the 12 volt battery and use that point as your 12 volt input source. Take your output from the 240 volt end. Choice 3 is buy, or build one from a conventional parts - as I did back in the late 1970s for a 200 RMS watt car amp.
kimbalsummers@hotmail.com Last edited by kimbal; 24th July 2012 at 11:16 AM. |
| need +/-85V 20A Stabilized ! help | grechejr | Power Supplies | 5 | 3rd January 2007 04:34 PM |
| Super T amp on 12V batt | Sarchi | Class D | 7 | 3rd May 2006 02:39 PM |
| Need Cross sch opera super pavarotti | stavros | Multi-Way | 0 | 19th April 2006 03:12 AM |
| Sch for Power Amp for Cars? | samsagaz | Car Audio | 5 | 13th December 2004 04:23 PM |
| 20A power supply | fmak | Solid State | 31 | 13th September 2004 02:17 AM |
