#41 |
Well... Depends how you measure? Right?
The 99 is achieved without the input and output inductors. With them the efficiency is down to about 95%. Could rethink the inductors a bit, but then again Im quite happy with the thing already as it is. Transformers are 6 turns primary made from copper foil 0.125mm thick x 16mm wide... Secondaries 2x 0.9mm 16 turns... Flat out power is 560W but I would blow the diodes pretty soon (MUR1560) with that, so adjusted down to 440W only... With 560W output power a 50A fuse holds - nice... FETs are the suggested IRF3703. Their advantage is the fast switch off, which results in to close 50/50 duty cycle... |
#42 |
37A at 12V makes 440W, right?
It takes as little as 3.2miliohms through Mosfets, transformer primary, PCB traces, inductors and cabling together to loose 1%, ie. 4.4W at 37A. It is very tough to achieve. Rectifer diodes drop a volt or so, that's another percent at 100VDC secondary and two percent at 50VDC secondary. Even a primary capacitor can be a bottleneck, a very good 10000uF cap will have like 20miliohms, draw several amperes through it and you loose another fraction of a watt, a watt or two. Switching losses don't usually dominate at below 50kHz. Ferrite cores are also pretty lossy unless you run them at <100mT. Don't worry, 95% is already a very good result, I wasn't able to achieve that high with 12V/600W push-pull with buffered IRFB3004, tight tape (foil) wound primaries, HV secondaries, sendust chokes and so on. |
#43 |
Hey! I was thinking about... If i want to put an over-current protection in a isolated SMPS, how can I do it?
#44 |
hi guys
sorrry for my bad english i have ETD39 and IRFZ44N can i use that? i did not see any pcb in this topic.!! please help me friends thanks |
#45 |
What is the advantage of full bridge switching with only an automotive B+? How is push-pull not inherently more efficient here?
#46 |
Ofcourse it is. Just put in a bigger core and there you have it.
I myself prefer fullbridge because of the ridiculously simple transformer. No need to worry about perfectly symmetrical primaries with just a couple of turns around the core. |
#47 | |
There's no PCB because we've been discussing theory, simulations, and industry standards. We're not at the actual assembly of his 575W (now 400W) supply. I posted a pic of my 500W supply just as a reference of one way it can be built. Keep watching for more details. Plus, read through this and other SMPS threads so you can begin designing your supply!
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
#48 |
Thanks for your reply and sorry for my bad english.
I am basic in electronic and i do not have a oscop to make a good smps. I buy the 800 number of TL494 and 1000 number of IRFZ44N and 300 number of ETD39 in very low price in my city. He quite him job and sele all of that things to me with half of price. I want to creat smps with that beacuse i have that. Sorry for my bad english egain. Please give me a chance with that parts. Thank you engineers. |
#49 |
#50 | |
| DIY smps + LM3886 Car Amplifier | rwaudio | Car Audio | 0 | 30th October 2008 03:06 PM |
| Bypassing car amplifier SMPS for use in home | 96tahoe | Car Audio | 8 | 3rd April 2008 09:50 PM |
| car amplifier SMPS | KettermanJ | Car Audio | 6 | 16th October 2007 12:31 AM |
| Car audio SMPS transformers | Toddy Audio | Swap Meet | 6 | 13th August 2004 03:39 PM |
| I want to build car smps and car amplifier | himanshuraval | Car Audio | 0 | 20th February 2004 12:40 PM |
