PSUD help - 26 heater
Old 1st June 2012, 08:44 AM   #1
Brouilly is offline Brouilly  United Kingdom
Brouilly's Avatar
Default PSUD help - 26 heater
Hi all,
Getting to grips with PSUD but I am getting some odd results - I am obviously doing something wrong and after a little guidance please.
Attached is the supply, copied from Rod Colemans notes on building a heater supply for 26 DHT.
I keep getting the "current pulled voltage below zero" alert, so I tried a stepped load 50mA - 1A after 2 seconds - Noticed that the voltage slowly rise as expected, but then plummets when it draws 1A.
Any input would be hugely appreciated. Was talking with Mogliaa last night and he is a big fan of PSUD so it would be good to use it more in my builds.
Many thanks
Charlie
Broke solderer with delusions of grandeur
Old 1st June 2012, 10:52 AM   #2
Brouilly's Avatar
OK so found the transformer rating settings, getting better results but still a lot of ripple.
Baby steps
Old 1st June 2012, 06:21 PM   #3
jamesdb is offline jamesdb  United States
Sorry but the 450 milli Ohms for the transformer does not sound realistic. Also the choke is way too low, 1 milli Henry is too small. Do you have that choke already, or can you select a different one?
Old 1st June 2012, 06:24 PM   #4
PS don't do a stepped load, 50mA to 1mA, just leave it at 1A.
Old 1st June 2012, 11:24 PM   #5
Loudthud is offline Loudthud  United States
Loudthud's Avatar
2 ohm ESR for 10000uF cap isn't right. Should be on the order of 0.1 ohms or less.
Old 1st June 2012, 11:55 PM   #6
Brouilly's Avatar
I measured the unloaded transformer voltage and resistance to get the figures. I corrected the capacitor resistance, which lowered the ripple to about 0.3v. As for the choke, it was part of the design set up for the Rod Coleman DHT boards, it's a common mode choke, and I also have 2 0.2ohm resistors on each rail after the choke that can not be simulated on PSUD.
I was playing around with stepped loads to see when the voltage dropped, but adjusted the transformer ratings so no problem there.
Thanks for the help - Learning a lot.
Charlie
PSUD help - 26 heaterHide this!Advertise here!
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
PSUD 2 mr2racer Power Supplies 4 7th April 2012 01:35 PM
Transformer for 26-0-26 Einric Power Supplies 5 1st March 2011 06:11 PM
Regulated Heater on the 6SN7 Aikido Plate to Heater question john65b Tubes / Valves 6 24th November 2009 05:44 AM
1.5VDC Heater Supply For #26!? Zekk Tubes / Valves 5 10th November 2009 12:33 AM
