hi,
2SK1020 is rated at 300W, with switced current of 92A and 30 A continours, i am planning to build power supply for my truck with battery at 24V. the indented power of amplifier is 4000W (assuming driving 4 subwoofers) , how many 2SK1020 should i be needing for switiching at 24V primary., i assumed with losses 200A should be the target , would 4 on each primary side of step up transformer should be enough? someone suggested me 2SC5200 BJT 150W , 30A Ic as a better option? any suggestions please ? any idea of heat disspiation and heat sinking requirement ? |
#2 |
or any suggestion for IRFP series mosfets ?
#3 |
IRFP 460 ??? PD 260 W??? 80 A pulsed current
#5 |
at the moment i am just concentrating on balanced pull push for the power supply . so how much 2SK1020 would i need to handle 200 A between 24V . ? any suggestions
#7 |
Can i use Solid state relays for switching ????? 100 A modules ????
Three-phase solid state relay - 100 A | APC6000 series - Anacon Power & Controls like this one???? |
#8 |
or an IGBT power module ???? like this
http://theelectrostore.com/datasheets/cm300ha12h.pdf this one is 1100 Watt, 300A |
#10 |
i have seen 70N10 and 80N10, very good power and current ratings for small VCE. any suggestions for using them in parallel, i have hand on LOT stock of FUJI 500A, darlington power modules, its rated 2000W with 500 A collector current. may be using 2 of them in parallel will abundant switching power. BTW its available at $15 a piece from a local vendor who breaks down old large UPS/inverters to salvage parts /
its FUJI 1DI500A-030, any suggestions ? |
| SG3525 for Inverter | xpikon | Power Supplies | 96 | 17th July 2011 05:23 AM |
| Phase inverter | ThSpeakerDude88 | Tubes / Valves | 37 | 29th August 2007 03:15 PM |
| Inverter | MaXiZ | Solid State | 32 | 27th March 2004 03:30 PM |
| Switching on and off a Voltage Inverter | punchpeanut | Parts | 1 | 18th December 2003 10:34 AM |
