howdy folks,
im new to all this diy audio stuff. anyway im bangin a power amp together and ive a fair idea but just need to check with you the good folks of the community, about affixing a torod transformer to a chassis. as far as i understand you can epoxy the center or put a cap on it (shaped like a cymbal) with two rubber mats one for top and bottom i suspect and a bolt through it.
1 - how would an epoxy centre work.
is it just glued into place?
2 - how does the bolt and cap work?
i think it goes rubber mat torod rubber mat metal cap with the cap concave into the transformer. from there the bolt goes down the middle from the top and is bolted on the bottom. sound about right?
im just not to sure how it all goes together. if anyone has any handy links or youtube vids that'd be tops. cheers all
howdy folks,
My advice would be to use whatever is supplied with the toroid.
The epoxy indeed acts as a glue, but the bond is incredibly strong. I have seen equipment returned that fell during transport. The aluminium plate on which the toroid was hung would be bent, but the toroid itself was undamaged.
The toroid is clamped to a chassis.
Yes, the toroid must always be in contact with the rubber discs and never any metal.
The plate and securing bolt MUST NEVER touch a metal top plate.
That would short the transformer.
Only if it's steel. It doesn't make a damn bit of difference otherwise.
The only reason for this is to prevent vibration from the toroid rubbing the plastic cover off of the windings and causing a short (after it rubbed through the coating on the wire also of course).
You can use a steel rivet nut on the bottom in place of the nut. It makes for a neater installation.
Yes - make sure that it`s fitted the right way round though or it can pull out with the weight of the toroid - I`ve seen this happen after kit has been shipped imperfectly packed.
Depends...small toroids sometime come with glued in mounting nuts, yet most and larger ones use steel mounting sets. You usually don't epoxy toroids yourself!howdy folks,
Any conductive material will short out the transformer.Only if it's steel. It doesn't make a damn bit of difference otherwise.
Steel is actually a bad conductor compared to aluminium. Copper and silver are even better conductors.
Carbon fibre is a bad conductor, but it will still short out the transformer.
This point has been raised before.Yes - make sure that it`s fitted the right way round though or it can pull out with the weight of the toroid - I`ve seen this happen after kit has been shipped imperfectly packed.
A back to front rivet nut has very little strength.
Unless you can provide proof, this is complete horse ****.
It has plenty for normal use when installed in reverse. Unless you have actually done it, then you don't know what you're talking about. I have, and they are plenty strong enough.
If you aren't using a riv nut (like me), it's a good idea to insulate where the bolt passes thru the chassis, and where the nut tightens on the bottom. Nylon washers and nylon tubing over the bolt works well.
Just prevents any possibility of creating a shorted turn scenario. As the top plate and the chassis act as cheeks, and the rest is history.
6J6.
6J6.
Or any other conductor- the thing to avoid is an unintentional shorted turn.
Like I say, I have seen it happen. Transformer rolling around in the case. Believe it or not - makes no odds to me.
What you call 'horse ****' is basic electrodynamics / transformer theory. Please go back to 'Start' and read the basics.
A closed conductive loop around the core (formed by the bolt and the conductive chassis) will act as a single, low-resistance turn, effectively shorting out the transformer, as AndrewT and SY stated correctly.
Andreas
- Power Supplies
- fixing torodial xformers to a chassis
