fixing torodial xformers to a chassis
Old 5th June 2012, 05:28 AM   #41
u1022186 is offline u1022186  United States
Hi All. Thanks for all the suggestions. The case I'm using is salvaged from an old amp and it's a really heavy duty case so weight shouldn't be a problem. The transformers are Antek as you mentioned. They weigh about 13 lbs. each and are about 6 1/4" in diameter. The case also has a lot of height (about 10 1/2"), so I thought I would build a two level platform to hold them both. That way I could leave about 1 1/2 inches between them for cooling. Does that seem reasonable?
Best Wishes,
Bob
Old 5th June 2012, 08:39 AM   #42
On Hiatus
SY's Avatar
More than reasonable as long as you have plenty of clearance between mouting bolt and top plate.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
fixing torodial xformers to a chassisHide this!Advertise here!
torodial transformer question east electronics Solid State 6 18th December 2009 07:44 AM
Output regulator after torodial transformer? freestylez Power Supplies 9 25th June 2009 01:46 PM
torodial transformers? monomonster Parts 23 17th October 2005 08:48 AM
Torodial Tranformer Calculation JanDH Parts 34 28th December 2003 02:34 PM
